Dyson Models => First Generation "The Ball" Dysons. => Topic started by: brett83 on July 27, 2014, 08:34:56 pm
Has anyone devloped a way of testing the brush motor PCB?
If there is a fault with them what generally is the problem, it only has 2 x resistor a capacitor and a bridge rectifier on board, so i susect the fault is usually the capacitor, but I havent tested any yet.
Brett
No mate, but I had one a while ago with an obvious dry joint. A small blob of solder and the job was a guddun!
