Author Topic: Cannot take off the switch cover of DC 18  (Read 4888 times)
Offline myopetz
« on: September 01, 2013, 02:22:34 am »
The main switch on my DC18 stopped working. I was trying to do the replacement myself. I took off all four torx screws at the back of the machine. But still I cannot get off the switch cover. The top is loose already, but the bottom appears to be still fastened by something. Anyone has the similar experience?
Thanks!
Offline __russ__
Re: Cannot take off the switch cover of DC 18
« Reply #1 on: September 01, 2013, 12:59:28 pm »
Thanks!
Put the bottom two screws back in their holes just a couple of turns - then with the screwdriver in place on each screw, either hit the end with the palm of your hand or a light tap with a hammer and it should pop that switch cover out. You've then just got to take the screws out and the cover should come right off  :thumbsup:
Offline myopetz
« Reply #2 on: September 01, 2013, 10:36:07 pm »
Thanks!
Thank you, russ! It worked magically ;)
