Author Topic: DCo7 Motor Exchange  (Read 4397 times)
Offline searswolds
DCo7 Motor Exchange
« on: September 24, 2013, 02:58:47 PM »
Hi. I have a DC07 but the motor has packed up. I have been given a DC04 with a good motor in it so can I fit the DC04 motor into my DC07?
Re: DCo7 Motor Exchange
« Reply #1 on: September 24, 2013, 08:30:44 PM »
It depends exactly which motor your DC04 is fitted with, and if a genuine one or not.
What colour combination is your DC04?
« Reply #2 on: September 25, 2013, 02:14:14 PM »
I've fitted YDK motors from DC04's into 07's a few times. Always swap the rubbers over so the 07 rubbers stay with the 07 machine and you should be fine.
Offline searswolds
« Reply #3 on: September 25, 2013, 03:52:03 PM »
Hi guys. Thank you for your replies. The DC04 is grey/green and has the original motor. I am going to try this motor with the DC07 rubbers. Thanks for your advice.
Offline __russ__
« Reply #4 on: September 25, 2013, 04:44:30 PM »
The lime green DC04 has an Ametek motor and therefore won't fit your DC07 unfortunately, even with the original rubbers.
Any other DC04 and you would have been ok!
« Reply #5 on: September 25, 2013, 06:46:02 PM »
Ah! My motor came from a yellow and silver one, and the one in the absolute+ would have been the same.
Bad luck chap. Search locally for a broken-in-any-way-bar-the-motor jobbie. Should pick something up for a tenner or so!
Good luck
« Reply #6 on: September 27, 2013, 12:54:49 PM »
Original DC04 YDK motors run slower than the DC07 ones though, so the DC07 with a DC04 motor will be slightly less powerful. As will a DC04 fitted with a DC07 motor be a bit strong and glue itself to the floor.
Aftermarket ones are interchangeable/the same.
