Author Topic: Dyson DC18 Undercarriage Exploded Drawing / Diagram / Schematic  (Read 26231 times)
I came across this on one of our old CD's today, I put it here in case it is of use to anyone here.
01. Gimble Lock Pin Assy DY-912373-01
02. Axle DY-911095-01
03. Iron Yoke Assy DY-912365-01
04. Titanium Outer Wheel Hub DY-911150-01
05. Internal Hose Assy DY-916579-01
06. Iron Swivel Cover DY-911159-01
07. Screw M3X10-T15 DY-910702-04
08. Wheel Fastener Kit Assy DY-912375-01
09. Iron Barrel Wheel Assy DY-911200-01
10. E-Clip DY-900146-01
11. Iron Under Carriage Assy DY-912376-01
12. Iron Lock Arm Assy DY-911101-01
13. Spring DY-911117-01
14. Clear Pedal Plunger DY-911099-01
15. Red Pedal DY-911097-01
16. Iron Stabiliser Wheel DY-911107-01
17. Black Microswitch Cam Assy DY-912372-01
18. Iron Microswitch Cover DY-911156-01
19. Screw M2.5X6-T8 DY-911338-01
20. Black Plastic Washer DY-911106-01
21. Black Microswitch Housing Assy DY-911154-01
22. Axle DY-911151-01
If you happen to need an undercarriage, we have them here: DC18 Undercarriage Assembly, the main DC18 parts page can be found >>here<< and anything you don't see you can >>contact us<< for a very keen price new or used.
Offline J Barlow Servicing
Re: Dyson DC18 Undercarriage Exploded Drawing / Diagram / Schematic
« Reply #1 on: June 14, 2014, 07:59:02 PM »
Replaced the wiring loom that feeds the brush motor on a DC18 yesterday :'( First time of doing so on this particular model, definitely not a 20 minute job and not for the impatient :boggleeye:
Online __russ__
« Reply #2 on: June 14, 2014, 08:36:50 PM »
Oh yes, everything out jobby!
Offline brett83
« Reply #3 on: August 04, 2014, 04:52:44 PM »
Ive just replaced one as well, brush still not working.  the old one was clearly open circuit.
Motor works on a DC powers supply,  buzzed out all the switches.  Its got me stumped !!
« Reply #4 on: July 03, 2015, 07:58:29 PM »
Here are the rest of the DC18 diagrams.
01. End Cap Assy (Left) DY-911701-01
02. Iron/Clear Cleaner Head Assy DY-911693-02
03. Cleaner Head Connector Block Assy DY-911087-01
04. Gimble Cover DY-911084-01
05. Brush Housing DY-911060-01
06. End Cap Assy (Right) DY-911702-01
07. Brushbar Assy DY-912397-01
08. Bumper Strip DY-911078-01
09. Soleplate Assy DY-912374-01
10. Iron Soleplate Wheel DY-909747-02
11. Soleplate Wheel Kit Assy DY-912367-01
12. Screw DY-910702-10
13. PCB Assy DY-911520-01
14. Screw M3.5X16-T15 DY-910703-01
15. Spring DY-900199-21
16. Iron Brushbar Motor Cover Assy (Upper) DY-912371-01
17. Titanium Swivel Catch DY-911073-01
18. Screw M3.5X16-T15 DY-910703-01
19. Brushbar Motor Mount DY-911094-01
20. Brushbar Motor Assy DY-911705-02
21. O-Ring DY-900170-28
22. Brushbar Reset Switch DY-911532-01
23. Brushbar Motor Front Mount DY-907356-01
24. Brushbar Motor Cover (Lower) DY-914295-01
25. Screw FNLA
26. Rope Seal DY-905950-01
27. Axle DY-911165-01
01. On/Off Switch Button DY-911035-01
02. Clear Brushbar Reset Arm DY-911746-01
03. Spring DY-900199-21
04. Brushbar Actuator DY-911034-01
05. Spring DY-900199-21
06. Switch DY-910971-01
07. Switch Cover DY-911029-01
08. Iron Tool Clip DY-904111-08
09. Exhaust Seal DY-911038-01
10. Crevice Tool Clip DY-907764-04
11. Inlet Seal DY-911039-01
12. Duct Motor Mount DY-911526-01
13. Lower Duct Cover Seal DY-911031-01
14. Lower Duct Cover DY-911030-01
15. Cyclone Release Catch DY-911037-01
16. Spring DY-919900-15
17. Spring DY-919900-14
18. Clear Wand Release Catch DY-911042-01
19. Screw FNLA
20. Black Connection Insulator DY-911041-01
21. Cable Protector DY-910359-02
22. Powercord Assy DY-911399-02
23. Cable Clip DY-904905-08
24. Screw M3.5X16-T15 DY-910703-01
25. Lower Cable Winder DY-911045-01
26. Duct Assy DY-912369-01
27. Screw FNLA
01. Post Filter Cover DY-911043-01
02. Post Filter Cage Assembly FNLA
03. HEPA Post Filter Assy DY-911677-02
04. Post Filter Assembly FNLA
05. Post Motor Seal DY-911044-01
06. Screw FNLA
07. Motor Retainer Ring DY-911051-01
08. Motor Retainer Seal DY-911048-01
09. Screw FNLA
10. Motor Retainer DY-911050-01
11. Motor Mount DY-911033-01
12. Motor Panasonic SDS1301GND 120V DY-911666-01
13. Motor Inlet Seal DY-911036-01
14. Female Connector Housing Assy DY-912368-01
15. Cleaner Head Coiled Cable Loom Assy DY-911049-02
16. Microswitch Loom Assy DY-911046-02
17. Internal Cable Looms Assy DY-912370-02
18. Internal Cable Assy DY-911040-02
01. Titanium/ Clear Cyclone Cap Assy DY-912366-01
02. Pre-Filter Assy DY-911685-01
03. Bin Seal DY-911079-01
04. Iron/Metallic Yellow Cyclone Assy DY-911698-01
04. Satin Purple Cyclone Assy DY-911698-04
04. Metallic Red Cyclone Assy DY-911698-05
05. FDC Seal DY-911077-01
06. Clear Bin Assy DY-911684-01
07. Clear Bin Base Assy DY-911683-01
08. Black Bleed Valve Housing DY-911090-01
09. Spring DY-919900-20
10. Screw DY-910702-08
11. Bleed Valve Cap Seal YDK DY-912930-01
12. Black Bleed Valve Cap DY-908672-01
01. Iron Wand Cap DY-911131-01
02. Iron/Red Wand Handle Assy DY-911695-01
03. Hose Assy DY-911694-04
04. Instruction Pack Assy DY-911671-03
05. Iron Combination Tool Assy DY-911708-01
06. Iron Stair Tool Assy DY-911707-01
Offline taran57
« Reply #5 on: April 14, 2017, 05:43:04 AM »
Its a pita they dont sell the bloody wheel brace by its self.
Silly changeover lug snapped off.
Might improvise with metal vs ordering a $65 undercarriage.
