Author Topic: Noisy DC23  (Read 5694 times)
Offline __russ__
Noisy DC23
« on: December 17, 2013, 03:45:27 pm »
I've got a DC23 Allergy that's cleaned up nicely but makes a horrible whine once switched on.
Visually everything looks ok and suction is excellent so at a bit of a loss  :'(
Any suggestions? Filter looks ok but wondering if it's not seating properly - don't have a spare to rule that out though!
Hoping someone might have come across this before  :tiphat:
Re: Noisy DC23
« Reply #1 on: December 17, 2013, 09:59:19 pm »
Did you take out and bench test the motor?
Debris down the intake is the usual suspect if you didn't.
Offline __russ__
Re: Noisy DC23
« Reply #2 on: December 17, 2013, 10:52:39 pm »
Interesting thanks for that  :thumbsup: Yes I had the motor out to check it ran good but didn't think/know to check the intake.
Bit of a pain as not the easiest cylinder to take apart but will have another look tomorrow!
Re: Noisy DC23
« Reply #3 on: December 18, 2013, 05:07:44 pm »
We find kinds tend to stuff things down the intake quite often. Felt tips and crap like that makes odd noises sometimes.
Offline Vacuum Cleaner House
  • Country: za
Re: Noisy DC23
« Reply #4 on: December 18, 2013, 09:48:37 pm »
Take out the hepa filter, If it has the moulded rubber seals on either end then get a new one. The rubber seals can leak air after a while. The  new hepa filters with sponge type rubber on either end replacing the moulded rubber seals they no longer whine like this with the new one.
  • Country: za
Re: Noisy DC23
« Reply #5 on: December 19, 2013, 01:09:23 pm »
Here are the dc23 hepa filters , Old style left new style right
Offline __russ__
Re: Noisy DC23
« Reply #6 on: December 19, 2013, 02:01:21 pm »
Brilliant, thanks for that  ;)
I'll have a look and let you know which style I've got - can believe the cost to replace though, even trade prices  :o
Offline __russ__
Re: Noisy DC23
« Reply #7 on: December 20, 2013, 09:40:35 pm »
Yes I have the old style HEPA filter - removed the filter, switched on and the noise disappeared  :thumbsup:
What I did do though was pull the larger rubber seal up so it sat right at the top the groove and when I refitted it like this, the whine was still gone.
I think just pulling the rubber seal out 1-2mm was enough to make it air tight again.
Will run it for a few days just to check the whine doesn't reappear but hopefully sorted without the expense of a new filter.
