Author Topic: on/off button  (Read 3717 times)
Offline jim1000
on/off button
« on: January 28, 2014, 06:50:51 PM »
Does anyone have an exploded diagram or instructions of how to put the on/off switch together as mine has fallen apart but nothing looks damaged but not sure how it goes back together
Re: on/off button
« Reply #1 on: January 28, 2014, 07:23:17 PM »
The actual button slots and clips into the switch housing. There is no spring, the switch does the springing. You need to make sure the cables are properly pushed into the moulding as otherwise the switch housing wont fit back on.
Offline jim1000
Re: on/off button
« Reply #2 on: January 28, 2014, 08:10:58 PM »
Its the switch itself as it has 2 little tabs which open it up, and mine was split went to puah it back together and it popped apart
Re: on/off button
« Reply #3 on: January 28, 2014, 08:17:32 PM »
Ah so the button is broken?
The button doesn't flex, it's the switch housing that opens out slightly to slide the switch out.
Is the actual housing broken, or just the clips stopping the switch from sliding out when clipped? If so it will possibly go back together and still work, as the switch cant move back when assembled.
I'll get mine apart in a bit and see if I ca nsee what you mean. Unless you've got any pictures of it?
Offline jim1000
Re: on/off button
« Reply #4 on: January 28, 2014, 08:37:50 PM »
It's the switch internals trying to upload my bits  can't get photos from phone to upload
Re: on/off button
« Reply #5 on: January 30, 2014, 12:42:01 AM »
A new one is 99p.
Offline jim1000
Re: on/off button
« Reply #6 on: January 31, 2014, 12:10:56 AM »
I know its not the money I just like to know how things go together so when I do break them I can fix it
