Author Topic: How to Strip Down a Dyson DC39 to Access the Motor  (Read 55996 times)
« on: February 28, 2014, 11:39:19 am »
Today we have done a motor swap in a DC39. So I thought we would document it for the benefit of others.
First, we remove the two wheels by undoing the T15 screw holding each one on.
And we then remove the swivelling undercarriage with the four screws:
Which then comes off like so:
Re: How to Strip Down a Dyson DC39 to Access the Motor
« Reply #1 on: February 28, 2014, 11:41:29 am »
Then we undo this screw - one on each side:
Followed by the four screws on each side here:
These two below (two of the four above) cannot be accessed without removing the swivelling mechanism:
« Reply #2 on: February 28, 2014, 12:01:18 pm »
Then the unit splits open like this, and we can see the HEPA filter inside and the motor bucket.
The motor bucket is opened using these clips: (there are three)
And then we can see the motor:
Which is a YV-16K24FA.
We keep these motors in stock which you can find here: Dyson DC39 Motor. The screwdriver you need is to be found here.
A note on reassembly: In the motor bucket, there are three rubber locators. They must be located in the corresponding cut outs in the motor cover or the motor will howl when reassembled.
Offline veremakl
« Reply #3 on: April 16, 2016, 01:12:27 am »
I am trying to replace the HEPA filter.  I have kids - don't ask why!!! I made it to the bottom of the page but I need to now disconnect the electrical - without causing harm.  I don't want to pull to firmly since I don't know what is on the other side or how it is actually connected.   Suggestions???
« Reply #4 on: April 16, 2016, 09:46:25 am »
You dont remove anything here,  you need to remove the motor from its housing,  then the wires from inside there and feed them out.
Theres a DC39 stripdown thread in the main forum,  that should show you,  and tell you how to seperate/reattach the motor housing to the filter unit
Offline pointandyrepair
« Reply #5 on: June 10, 2017, 08:14:10 am »
Thanks for this post. It helped me replace my broken motor.
Offline Shirlzz
« Reply #6 on: July 03, 2017, 03:10:24 am »
Thankyou for posting the photos, I had removed the motor because it made a burning smell. I checked the brushes but when it came time to reconnect it I was unsure what side the black and white wires attached too but your photo saved me. unfortunately nothing can save my motor. when i tested it out side the housing it was sparking like fireworks.. been told that means its on its way out..is this correct?
« Reply #7 on: July 03, 2017, 01:39:44 pm »
Yes, if its sparking it is almost deceased, Shrilzz. New motor time.  :dead-dyson:
Offline bondy70
« Reply #8 on: November 01, 2019, 08:54:33 pm »
Does it matter which wire (white or black) is connected to which terminal on the motor?
« Reply #9 on: November 02, 2019, 07:58:04 am »
Technically it shouldn’t actually matter. However the photo above shows you which goes where.
