Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
With photos. Find it
>here<
Click
>here<
Home
Help
Login
Register
Dyson Models
Dyson DC01 (and DA 001)
Unable to detach wand
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Unable to detach wand (Read 3383 times)
Linda Brownlee
Member
Country:
Gender:
on:
April 06, 2014, 05:05:18 PM »
Tweet
I have inherited a DysonDC01 in my rented accommodation but have been unable to detach the wand no matter what I do? Any ideas?
Logged
MVacs
Administrator
Member
Country:
Gender:
Re: Unable to detach wand
Reply #1 on:
April 06, 2014, 06:08:03 PM »
You take off the cable, depress the coloured clip and pull it up. So yours is jammed?
Logged
Check out our poll here:
Linda Brownlee
Member
Country:
Gender:
Reply #2 on:
April 06, 2014, 08:41:29 PM »
Yes - jammed with no sign of ever detaching!! The machine looks well used but the wand tools are all in perfect condition as if the previous owner has bee unable to take it part to use them - very very frustrating. Its not working well at all - picks up and then spits everything back out again a few inches away!!
I have tried cleaning it but no improvement......
Logged
MVacs
Administrator
Member
Country:
Gender:
Reply #3 on:
April 07, 2014, 02:06:50 AM »
The spit out problem is a blockage. Take off the complete soleplate with the few screws and unblock the channel there.
The wand is probably a kink or muck in the back hose that is holding it in at a guess. Only brute force will remove that and then investigation to see what was holding it in.
Logged
beko1987
Member
Country:
Gender:
Let's take it apart!
Reply #4 on:
April 08, 2014, 09:21:29 AM »
Just be careful yanking it out, the plastics can be very fragile!
Once you do get it out, check the two rubber flaps underneath where the wand goes as well as under the soleplate, blocks up there too if long thin things are vacced up!
Logged
Linda Brownlee
Member
Country:
Gender:
Reply #5 on:
April 09, 2014, 07:06:39 PM »
Thanks for the tips but although there was a ridiculous amount of stuff packed in there that came out when I removed the sole plate I can see through from one end to the other is clear down the tube but it still won't shift.
Now there's a very strong smell of burning rubber so I've given up and taking it to a repair man!
Logged
Print
Pages: [
1
Go Up
« previous
next »
Dyson Models
on
