Author Topic: Dyson DC02 Teardown and refurb  (Read 25829 times)
« on: May 11, 2014, 11:29:02 pm »
I pulled the DC02 out of the loft earlier in a bid to start refurbishing what I have rather than keep buying!
It's quite faded sadly but top notch otherwise.
The small tools are unused!
Popped the cover off
Removed the very tricky to refit looking seal and hose socket
Suction inlet now
Pedals off
Bottom half now
Motor housing off
Wheels off
Seal off
Refrence shot
Cord reel out
Motor out
Foam and locating assembly removed
Motor seal off
Motor looks ok
Empty now
Wheels off. Couldnt get the yellow housings out though
Switch apart
Moved on to the cyclone
Release valves out. Anyone got any tips on refitting these? The rubber sleeves were halfway down the spring by the time I pulled them out
Cyclone split
Yummy
Hose stripped next. Need a new one of these eventually but this will do for now
And then the floortool
And all done! All washed now too and drying in the airing cupboard!
Need to hunt some filters down, and a new hose end. But thats not urgent
Re: Dyson DC02 Teardown and refurb
« Reply #1 on: May 11, 2014, 11:56:24 pm »
For anyone else stripping one of these down, there is a step-by-step guide here.
We have quite a lot of stuff for those still Beko in case of need. We'll do stuff to you at happy money to keep you off eBay.  :chuckle:
We also have some new turbo heads.  :-X
« Reply #2 on: May 12, 2014, 12:05:48 am »
You know what I was thinking about turbo heads earlier...
I'll finalise the list and ping you an email!
Didn't see your other thread, sorry. I'll post some afters when its all done.
« Reply #3 on: May 12, 2014, 07:08:28 am »
I only highlighted the old Medic post so surfers also have locations of screws, etc.
Did I mention the DC02 turbo heads are new and boxed?  :evilgrin0002:
« Reply #4 on: May 13, 2014, 05:01:32 pm »
No you did not!  :coffee:
Will ping you an email on payday (been told to not spend anything else under pain of death sadly) with what I need. Still have to put it back together yet!
« Reply #5 on: May 14, 2014, 08:08:46 am »
Well, all washed, polished and back together!
Sadly the already biffed on one side release valve copped it fully on the hose handle so taped up for now until I get a replacement!
Will run it round tonight and see how much better it is! Then do nothing until payday when I furnish it with stuff!
« Reply #6 on: May 14, 2014, 06:38:48 pm »
Right. Test drive complete and its leaking suction from I think the release valves.
Currently they are fitted as:
Yellow top with the x facing upwards, tucked under the moulding
Spring under there
Rubber grommit sat at the bottom with the spring sat in there
Any ideas? The hose won't hold itself to my hand, and there is an air escaping sound when the lid is closed.
Wondering if its the lack of filters making the airflow too high but reluctant to shell out on filters ATM until I've tried other options!
Offline Angus Black
    • Dyson Medic
« Reply #7 on: June 05, 2014, 11:02:47 pm »
The relief valves were terrible on these.
There used to be a small kit to repair them, probably now obsolete. Ask Mvacs if they have any. They did about two years ago still.
« Reply #8 on: February 22, 2015, 07:20:28 pm »
Well,  amusingly someone is using the first picture on this post to sell their own dc02 somewhere in Northwich,  God knows where that is...
http://www.gumtree.com/p/for-sale/dyson-dc02-vacuum/1101362847
« Reply #9 on: February 22, 2015, 08:08:47 pm »
 :o
Obviously they don't have a camera and have done a google picture search,  bit of a liberty though.
http://en.wikipedia.org/wiki/Northwich
« Reply #10 on: February 22, 2015, 08:19:53 pm »
Aaah,  up north!
I'm more flattered than upset tbh,  and it means my content is gradually obviously filtering into the top of Google searches.
I've fired off an email in a light hearted way,  if they reply nicely I'll point them to the refurbished after pic so they can change it!
« Reply #11 on: February 22, 2015, 09:10:46 pm »
It's Norwich not Northwich.  He definitely has a camera,  or access to one,  as all his other ads are mainly pics of the van he has for his removal service! Unless he's stolen that pic too...
It's a breach of Gumtree T&C's,  so report it to them and they should take it down.
Offline Eddie Honda
  • Country: ie
« Reply #12 on: February 05, 2016, 01:28:24 am »
I thought I'd add to this thread than start a fresh one.
If you are really wanting to pop the front wheel holders out, here is what I did.
If the wheel holder is turned to face inboard, then it can be seen that there is a single lug (arrowed) which holds the collar of the wheel holder in place.
DC02 Front wheel holder 001 by E Honda, on Flickr
Carefully lever this lug just enough (whilst holding the wheel holder away from the lug) so it rests on the very side edge of the wheel holder. When it is stuck on that edge, the wheel holder can be twisted out (rather than directly pulled out) and that's it.
DC02 Front wheel holder 002 by E Honda, on Flickr
DC02 Front wheel holder 003 by E Honda, on Flickr
DC02 Front wheel holder 004 by E Honda, on Flickr
DC02 Front wheel holder 005 by E Honda, on Flickr
« Reply #13 on: February 05, 2016, 08:34:03 am »
Yes, I did learn that, but on the DC02 clear removing the wheels. I did this, then SNAP PING *duck*
You'll be amazed at the difference after you've washed and ciffed it looking at the underside of that!
Offline Eddie Honda
  • Country: ie
« Reply #14 on: February 05, 2016, 04:30:43 pm »
Errm, well  :grinn: I suppose the clear is made of a different plastic that has less give in it? Or is it like those shatterproof rulers that flex so far then just go SNAP PING? Maybe heating the plastic up before attempting might work better? I'm just throwing ideas out there as I don't intend to buy a load of Dysons to find out. Actually, knowing how it goes together, I'd have another cunning plan.
I've heard talk of faded DC02s, but as I've only come across one, which isn't, I can only speak for what I see. All I know is that it was here when I moved in and we've been here four years. In all that time it's been sat in the airing cupboard doing nothing. The only thing I can see with the plastic is a very slight yellowing of it. I presume that is like 1980s computer stuff where the flame retardants in the ABS plastic discolour over time.
