Author Topic: Brushbar power intermittent.  (Read 5955 times)
Offline Minal
« on: June 05, 2014, 05:19:47 pm »
The brushbar in the cleaner head assembly only works intermittently. To make it work I have to waggle the handle from left to right until the cleaner head motor starts.  would that problem be cured with a new DC 25 Yoke Assembly Loom?
Offline Angus Black
    • Dyson Medic
Re: Brushbar power intermittent.
« Reply #1 on: June 05, 2014, 10:55:39 pm »
The brushbar in the cleaner head assembly only works intermittently. To make it work I have to waggle the handle from left to right until the cleaner head motor starts.  would that problem be cured with a new DC25 Yoke Assembly Loom?
The problem you describe is typical of a loom with a broken wire. The wire makes intermittent contact as the machine moves so the brushroll motor is similarly intermittent in operation.
99% Yoke Assembly Loom.
Offline Minal
« Reply #2 on: June 06, 2014, 07:28:42 pm »
Having bought the loom, are there installation instructions and drawings?
« Reply #3 on: June 06, 2014, 08:47:54 pm »
You should get some clues here on Beko's strip down: https://manchestervacs.co.uk/DysonForum/index.php/topic,1060.0.html
