Author Topic: DC24 HELP  (Read 3319 times)
DC24 HELP
« on: July 25, 2014, 01:50:19 AM »
Hi, I got a DC24 for 33 today! :)
It was advertised with a non working brushbar, but luckily the brush motor works :)   ;D
The brush does not spin because the cog and the brushbar are not connected well. There is a gap, but the seller had it for 3 years? How can I fix this at home? It's the early type cog btw.
The thing also has another problem, and that is the brush switch is sticky, it's really stubborn.
Re: DC24 HELP
« Reply #1 on: July 26, 2014, 10:04:51 AM »
Is the cog worn or the brushbar? Look also at the end cap, if that is worn, it will allow movement.
Re: DC24 HELP
« Reply #2 on: July 26, 2014, 11:17:03 AM »
I am not sure which one is worn tbh, both look okay
BTE I fixed it now :) I put the brushbar directly on the cog, no problem.
Then, I got 2 pieces of rubber and put them in the end cap to fill the gap up, now there it a filled gap which is rubber and acts like a spring whenever it needs to to prevent putting strain on the brushbar, end cap or cog. It's brilliant now :) just sometimes makes a slight rattle once in a while
