Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
With photos. Find it
>here<
Click
>here<
Home
Help
Login
Register
Dyson Models
Dyson DC01 (and DA 001)
DC01 Main seal upright to swivel head
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: DC01 Main seal upright to swivel head (Read 4229 times)
ash4700
Member
on:
August 25, 2014, 09:55:30 AM »
Tweet
Good morning all,
I have a DC01 about 12-13 yrs old, and have noticed that suction from brush head is not as good as it used to be. I have found air leaking past main seal between the swivel head and the main body of the machine. THe seal is located by the RH wheel. I found a picture on this forum & have attached (hopefully I have I've done this correctly :) )
I don't know if the seal is the problem or the amount of play on the main pivot. When in the working position you can move the the head unit up against the seal & this appears to reduce loss of suction.
Is there a repair kit or components that allow you to tighten up wear in this pivot and also replace this main seal?
Many thanks for any advice tips you can supply.
Logged
Parwaz7862
Member
Country:
Gender:
Dyson geek 😃
Re: DC01 Main seal upright to swivel head
Reply #1 on:
August 25, 2014, 01:23:00 PM »
Is the cleaner head pivoting point worn out? Near the motor spindle, does the head wobble? If so, then that can cause a gap for suction loss
Logged
ash4700
Member
Reply #2 on:
August 31, 2014, 11:42:19 AM »
Thanks for feedback.
I have searched through forum and internet but cannot see anything to advise if there is a kit or spare part offered to tighten up the pivot.
Can anyone advise if there is something available to tighten up the pivot?
Logged
beko1987
Member
Country:
Gender:
Let's take it apart!
Reply #3 on:
November 14, 2014, 01:07:43 AM »
There won't be anything out there to do that I'm afraid!
Got a picture of the pivot on the floor head, and of the seal? Might be able to spot something amiss. Also, what's the pivot on the other side like? The yellow surround seated on the stub correctly etc?
Logged
DC01020304vacs
Member
Country:
Gender:
Me, myself and?? My Dysons
Reply #4 on:
November 14, 2014, 10:30:55 AM »
I've got a feeling that recently I saw the main pivot seals for dc01 foe sale somewhere. I've been on many websites recently could I be wrong??
Logged
DC01, DC02, DC03, DC04, DC05, DC07 + USA DC07, DC11, DC15, DC16, DC17, DC18, DC24, DC25, DC26, DC27, DC41, CYCLON !!
beko1987
Member
Country:
Gender:
Reply #5 on:
November 14, 2014, 10:32:41 AM »
Id imagine there's a few out there still!
Logged
beko1987
Member
Country:
Gender:
Reply #6 on:
November 15, 2014, 11:40:23 AM »
Well I reckon mine was caused when the base plate is on
Floor head was smooth without the base plate, put the base plate on and it got stiff again. Seems to be fixed by a smear of grease on the seal, and backing the screws off by a mm by the belt area.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Dyson Models
on
