Author Topic: DC41: No Power to the Cleaner Head.  (Read 7295 times)
« on: December 07, 2014, 07:53:38 PM »
We have found something else that causes problems on the DC41. Similar to the DC40 where a small loom breaks, we have found some DC41's that also have a similar problem. We have seen a trend of this in recent weeks, so it is worth a mention here.
When the machine is stripped down, you are looking here:
And here that is a bit closer:
As we can see, the wire rubs on the machine and eventually breaks on some machines causing power loss to the cleaner head.
The part is fiddly to change, but it is available.
It may be the case that Dyson discovered this already as the part number has already changed, suggesting a revision of some kind. More sheathing probably. The original part number was 921076-01 described as a "Motor Loom Assembly" and the new one is 963705-01 described as a "Motor Loom Service Kit".
We have just ordered a bunch of the motor loom service kits in, so they will be on the site within a day or two.
Online Madrat
Re: DC41: No Power to the Cleaner Head.
« Reply #1 on: December 07, 2014, 08:35:24 PM »
Thanks for the heads up on that.  :thumbsup:
« Reply #2 on: December 09, 2014, 10:34:14 AM »
These have now arrived and they look like this.
They can now be found on our shop here: DC41 Motor Loom Service Assembly.
The only "modification" I can see is a little bit of sticky foam in the packet. As they break in more than one place, that is useless as a fix.
« Reply #3 on: December 09, 2014, 08:12:42 PM »
Just as an addition to this, we got a DC41 in today that had exactly this problem (good job the looms had just arrived).
I think this is something we are going to see a lot of.
This one broke in a nearby, but different place, where the wires pass through the hole in the chassis - hard to spot!
If you have encountered this, say something on the topic here, and lets see how big a problem this loom breaking is.
Offline polkadots
« Reply #4 on: April 08, 2016, 05:18:39 AM »
I believe I have this problem; the brush roll motor cuts out at a certain angle. How do I get to the wire? Is there somewhere you can point me to that already has that information? Thanks!
« Reply #5 on: April 08, 2016, 02:12:45 PM »
The 'certain angle' bit is the telltale sign of a DC25 doing the same thing
Offline polkadots
« Reply #6 on: April 10, 2016, 01:45:09 AM »
(Attachment Link)
Is there anywhere you can point me that explains or shows how to get to this wire? Thanks!
« Reply #7 on: April 10, 2016, 02:33:51 AM »
(Attachment Link)
I am not sure anyone has actually done the tutorial for this yet.
Offline polkadots
« Reply #8 on: April 10, 2016, 02:43:49 AM »
(Attachment Link)
 :( :( :( Sad. Do you happen to know if the DC41 is like the DC50?
« Reply #9 on: April 10, 2016, 11:35:42 AM »
The DC40, DC41 and DC50 are all very similar in terms of how they come apart.
Offline seb
« Reply #10 on: September 07, 2018, 04:36:05 PM »
Hi I have a Dc41 which I have fitted a new brush head and still did not work. I fitted a new reset switch which went bang when switched on. The original switch looked as if it may have went the same way.
Any idea of what is wrong...we live in dundee so cant pop by
Online ryevac
  • Trev - not my choice of name - i was given it....
« Reply #11 on: September 08, 2018, 01:24:49 PM »
I haven't done many dc41, but if it has the small pcb fitted in the ball assy then it sounds like there could be a short circuit on that over the primary supply to it.
The original brush head may not have been at fault and was actually the pcb at fault.
Offline Gary Waterman
« Reply #12 on: January 04, 2019, 12:47:00 AM »
The cable on my dyson is intact but yet the brush head is not spinning I have taken it apart to have look and nothing seems to be out of the ordinary. CAN ANY ONE HELP PLEASE.
« Reply #13 on: January 04, 2019, 03:19:00 PM »
You have established its intact with a meter? Or visually?
