Author Topic: dyson dc24 main motor swap finally found a good use for dc03 motors  (Read 4345 times)
Offline geegar
 hi all around 4 months ago i was tidying my workshop bench after having a messy day and i had an old dc24 ydk motor on the bench i also had a dc03 motor sitting there from a very battle scared dc03 as they were sitting side by side they looked very similar in size, bing eurkia moment, lets try it for size so i slid the dc24 rubber over the dc03 motor and tried it for rough fit into the dc24 motor bucket well it fits apart from the spindle poking into the hepa filter housing, so out comes the hacksaw and off with the spindle, next step the tails on the dc03 motor are female so i cut off the male tails from the old dc24 motor striped the wires dug out soldering iron and shrink tubing all sorted put it all back into the motor bucket and fitted it into a test dc24 duct assembly run for 1hr to bench test, wow it worked so i stole the wifes dc24 and swapped the motor in hers for this dc03 motor we are now 4 months down the line and it is still running great with good suction. so it looks like there could be a use for all those dc03s that people hate so much!!!
has anyone spotted this or even tried it?
before everyone starts saying that its wrong to be trying to bodge fit other motors into a dyson most that are in the trade would of or still are puting a dc04 motor into either a dc07 or dc14 or cut the spindle off of a dc07 motor and fitted it into a dc08 or dc19 etc or even cut the spindle off of a dc04 amtek motor and fitted it into a henry.
i have done it as more of an test to see weather it could be done and thought that i would share my findings with all on here so if you have a spare 30mins and the parts to try it then have a go and let me know your findings or thoughts.
Re: dyson dc24 main motor swap finally found a good use for dc03 motors
« Reply #1 on: December 20, 2014, 02:40:28 PM »
I have actually looked at the two side by side and mused about his very conversion. Its great that you have given it a shot, DC24 motors are quite expensive.
So a DC04 Ametek fits a Henry as well? You learn something every day.  :icon_nod:
Offline geegar
« Reply #2 on: December 21, 2014, 01:13:19 AM »
Thanks for the reply r.e Henry it's only the single speed hvr200 I think again you need to remove spindle and change thermal cut out
 NUMATIC HENRY HVR200 AMETEK UDS1053SN
Genuine Dyson DC04 DC04i Ametek Vacuum Cleaner Motor Assembly 911930-01
If you google the part numbers and then compare the pics there is no difference other than the spindle it will also fit other Henry's with the metal bodied AMETEK motor.
When your tec guy has a few spare moments get him to have a look and post the findings
