Author Topic: DC17 u-hose removed and cant get it back on  (Read 5012 times)
Offline xians421
« on: January 11, 2015, 12:51:12 am »
Clogged so I took it apart down at the u-hose and cant figure out how to reverse the process.
See pics
Offline xians421
Re: DC17 u-hose removed and cant get it back on
« Reply #2 on: January 12, 2015, 09:20:13 pm »
Thanks, I have that figured out, but wonder how I have 3 holes to fill and only have 2 holefillers. Or am I overthinking it?
Offline autovac01
  • Woman in a man's world.
« Reply #3 on: January 13, 2015, 09:44:24 am »
I've not worked on a DC17 but think its the same idea as DC4/7/14/33 which are more common.
You have two parts in the picture, the ubend which goes underneath and the valve pipe at the side.
The valve pipe is the one I think you have 3 holes for because it switches from suction underneath to suction from the hose. so in the upright position it connects with one hole that allows air to flow through the hose, then as you tilt the handle backwards it lines up with another so the air flows from the head.
Offline xians421
« Reply #4 on: January 15, 2015, 03:59:44 am »
Thank you Autovac01. But by the time I read it I had already smashed it all back together.
Thanks for the help everybody, this is kinda like my BMW motorcycle forum. I'll be back I plan on kepping this one running for ten more years. ;)
