Author Topic: Help with dismantling DC04  (Read 3363 times)
Offline Telstar
« on: January 11, 2015, 10:59:04 AM »
I need to replace the motor in my ancient DC04 but I've hit a problem taking it to bits. I need to remove the height adjuster cover but it won't budge! The Youtube video I've been following shows it just being prised off using a screwdriver as a lever, but it just isn't shifting. Help!
Re: Help with dismantling DC04
« Reply #1 on: January 11, 2015, 01:39:16 PM »
You mean the clutch cover I presume? On the lh side as you look at the machine
It is a fiddly thing, and indeed snaps off with a flathead screwdriver. Prise out from the bottom and the top, and it should snap out eventually.
Be careful though, if its gone brittle it may snap. Used ones aren't too expensive though.
Offline Telstar
« Reply #2 on: January 11, 2015, 02:03:54 PM »
Thankyou. Just a bit more brute force and swearing needed, then! I'll have another go.
« Reply #3 on: January 12, 2015, 10:23:15 PM »
Pretty much! You got it off yet?
Offline Telstar
« Reply #4 on: January 13, 2015, 09:11:07 AM »
Yes, I finally got the flippin' thing off. Dyson now all in pieces on the dining table, waiting for the new motor to arrive.
DC04 Spare Parts
