Author Topic: Hoover Turbopower U2194 Refurb  (Read 8689 times)
« on: February 28, 2015, 06:21:29 pm »
I saw this on ebay for an incredibly cheap price, so, one thing lead to another and it was delivered to work last week. I took it round to mums at lunchtime and unpacked it
November 1984
Back at home, I had a closer look
it wasnt too great out the box. The belt kept slipping off on the lowest setting.
Had an old air freshener in it
The lower cord hook was in tact!
Seems to have had a replacement earlier base plate (the cable is brown as well)
Was in a right old state though
I had a set of tools about that I got from Freecycle, so set it up for above floor cleaning
Onto the stripdown then!
Trunnion cover off
It's a Perivale machine!
Eased the hinge pins out of the bag door
and out of the trunnion cover
Dirty
The smell dissapeared many years ago on this one!
threw it in the bin!
Bag door catch now
Screw out
and the bag door was stripped!
Can get to the rest more easily now though
The bag fill tube has washers under the screws, none of my other machines have this!
Lots of red dust was over everything! Was either powder paint or brick dust
Cover plate for the wiring was out next
Handle came off
Switch out
handle wiring plug comes out next
Has been jiggling about a bit I fear though
Cord clamp out
Wiring removed from the choc block
top cord hook removed
Up top was done, time for the bottom half
base plate off
Crap belt thrown away, and the activator removed
End caps were full of rubbish
Bearing housings looked fine though
Bearing components looked in very good condition
I binned the bearings, and took the belt guard out
Time to lift the hood
Height adjuster knob removed
Lightbulb was filthy
and the whole motor was covered in a film of carbon dust
The wires get unplugged from the junction box
The spinal cord can be removed now
Hinge plates out
Release pedal out
Locking ring pulls off
The bottom cord hook is imamgulate, and I left it well alone, dont want to snap it re-fitting it when it doesnt have to come off anyway
Crap pic but the cable tie holding the bellows on was removed
Motor clamp removed
and the motor lifts out
anti vibration foam removed
On the early ones, the front wheels are held in with brackets
The underside was covered in a layer of filth
Height adjuster out
Wheels off, and the outer caps need to be removed first. The tabs pop out easily from behind
Wheels are held in with small circlips
Furniture guard lifts off the chassis
Onto the motor now
Rubber seals/mounts off
Bellows off
The fan case comes off now
The motor casing comes apart now
After the fan... which also had red stuff underneath it
Wiring reference shot
reference mark made on the housing so it goes back together the right way round
4 screws out and it seperates
the armature lifts out
Top compression spring and washers pop out
Coil was in good condition
carbon brushes have a bit of life left in them
fancase bearing was shot
but the fancase itself in good condition
One box of washing
(camera lens was covered in dust, sorry for the lack of focus!)
more washing on the sofa
tub of non washables
and some screws
I cleaned up the gunk from the coils with a baby wipe
as they were a bit minging before
Wiped the spinal cord clean
Re: Hoover Turbopower U2194 Refurb
« Reply #1 on: February 28, 2015, 06:21:56 pm »
and once everything was washed, I grabbed the motor and activator parts out for re-assembly
Carbon brush holders back in
Grabbed the turbopower box out, and grabbed a new motor bearing
which didnt fit, and upon closer inspection q know who have sent me the incorrect ones on my last order, so I have 10 random bearings, and 10 less tp motor bearings than I thought  >:(
Sorted the box out to seperate them and carried them on
Found a new re-greasable one, topped the grease up inside it and slotted it on
sat the coil back onto the fancase
top ancilleries back in
Wires re-fitted, and a new cable tie fitted
Didnt change the top bearing, as it felt fine, and they are a pain to change (may be able to change them in future though, will elaborate on that when I get to it) so I left it for now!
2 fan washers fitted
fan was cleaner now
fitted
I popped into the shed, and found the remains of the sealent I bought to re-seal the sump on my girlfriends stupid bloody vauxhall...
un-plugged the nozzle
and ran a (thicker than normal as I cut the nozzle wide for the sump mating face) bead around the housing. It stunk alot more than it did outside...
Seems to be a nice seal. I left it infront of the radiator overnight to cure
Onto the activator now. I think the activator is a replacement part too, should be brown not blue, but it's in such excellent condition I decided not to care!
2 shiny new brushroll bearings fitted
and the activator is back together
Onto the main machine now
motor foam glued back into place
end mount onto the fancase
Grabbed the height adjuster after that though, as its easier to fit without the motor in weighing it all down
Wheels on top
I then couldnt find the spring for hell, so I fitted the brackets so they wouldnt get lost either and moved on
Wheels refitted
and the caps back on
cleaned this cap up to get rid of the paint
Onto the bumper next
A good ciffing to remove all the gunk and it slotted back onto the chassis
motor mount fitted into the chassis
bellows fitted
and the motor slots into place!
Activator back in with a new genuine belt
Pivot points were greased up to avoid any more wear of them
the top half was sotted in behind the bellows and into place, after putting the reclining holding part in...
Screwed down
Spinal cord fed through
fitted the cord whilst there was still some slack before channeling it away
The bulb cleaned up nicely
I fitted the hood, then the baseplate
Top cord hook fitted
cord fed through
and wired up
wiring cover fitted
I fitted the handle wiring slightly differently, to ensure a good non sparky connection
Then pushed the handle body over that. The little palstic peg was missing sadly, so I improvised with a small screw with a nice head
refitted the switch
Bag door now, and the latch is refitted
Hinges were fitted, and the trunnion cover screwed in place
Bag fill tube back in place
The empty bag that came with the machine was previously used i think, and looked smeggy, so I found a nice new bag!
and finally, the bag door could be fitted!
Last night now, and I waved SWMBO off to work, Eva was at granny and grandads, so I taped up the decals on the machine
and got the rotary out!
Not all the damage came out, but the gloss and clarity came right back into the plastic!
Once polished and buffed, I covered it in a layer of wax and left it to haze
I found the height wheels spring under the sofa so fitted that
All the wax was buffed off, and she was done!
It worked much better after that!
« Reply #2 on: February 28, 2015, 06:40:24 pm »
Nice.
I never realised they were dirty fan machines.
« Reply #3 on: February 28, 2015, 06:42:59 pm »
All the Turbopower 1s were.  Clean fan came in on the Turbopower 2 onwards
« Reply #4 on: February 28, 2015, 06:50:53 pm »
Ah that explains it then, not much different from the old starlight/junior deluxe then, just a more modern dress.
« Reply #5 on: February 28, 2015, 06:56:53 pm »
Pretty much!
