Author Topic: Dyson DC05 Absolute+ - Stripdown and Refurb  (Read 11316 times)
« on: March 29, 2015, 09:50:41 AM »
I took a chance on this machine a few weeks ago for £4, poor little thing
Was advertised as being dead. I took a chance on it being the cable and not the motor...
It had blown itself apart by the plug (common issue)
The rest of the cable wasnt up to much either
But, I re-stripped the end of the cable, fitted a new plug as the white one was cracked and voila, she fired up beautifully
Seems to have gained a different coloured upholstry tool at some point
The floor tool has a metal soleplate too, I thought they were only on DC02's? All DC05's I've seen have had plastic sole plates.
One problem that wasnt mentioned on the ad is the broken extension pole
I did try to fix it, but it held for about 2 minutes before breaking again... luckily I have a spare DC05 Extension wand in the loft (handily) so swapped them around.
I moved onto the stripdown now.
Floortool first
Soleplate off
Pushed out the litter pickers from the back
The wheels removed easily thankfully
as did the attachment bit
I cant take these apart anymore without damaging them so left it as that and washed it whole..
Removed the banana end from the hose and got the tools ready for washing
Finally on to the machine
Cyclone off
Post motor filter seems ok
Oh
The pre filter looks ok though
popped the top handle/filter housing lid off
Removed the seal
removed the mini cyclone thing
and removed this hair from it
I looked at the wheels next
but wasnt able to get the centre bit out without potentially damaging it, so left it for now
Instead, I managed to get at all the screws with the wheels still on to get the case open
Removed the cable guide
Can see the back of the wheels now, and the back of the plastic pegs
You can see where I tried to lever the left one out from the front... they smack out easier from behind!
motor to cord rewind wiring
Looking at the cord rewind, it seems different to madrats guide
The cable unplugs from the reel and simply pops out of the locating tabs
Without the weight of the cable on it though, the reel started to veeerrryyy slloowwllyyyy unwind so I grabbed a cable tie to stop it loosing tension
Onto the motor now. The front bumper is removed
The motor housing slides out of the chassis now
The front hose holder and cord rewind and power buttons pop off the chassis
Quick wiring reference shot
Wiring released, the motor can be removed
Removed the front wheel
Onto the cyclone next
Cyclone bin emptied
Onto the cyclone unit, 2 screws off
ans the release valve comes off
and then apart
Rest of the cylone comes apart by pulling
All done! Hardly any screws at all on a DC05!
Everything was washed and dried. I put a new cable onto the cord rewind
Lovely
Played around with the tension a bit and now the plug nearly smashed through the casing if you leave the reel to do its job...
General re-assembly now
Cyclone
Shroud back in
top cone fitted
Release valve re-assembled
lower cone back together
To the chassis now. front wheel back in
Motor went back in the motor housing
and the motor housing was done
fitted the hose holder
Then, I refitted the switch, and lowered the top chassis housing and bumper back on
Cord rewind next
Lower chassis housing fitted
Hose port snapped on next
followed by the pedals (had to remove the hose port to fit the cord rewind pedal...)
Back on with the wheels
and in with the pegs
New post filter in
Washed pre filter back in
floor tool back together
And done!
Re: Dyson DC05 Absolute+ - Stripdown and Refurb
« Reply #1 on: March 29, 2015, 04:10:32 PM »
Different cable real, wheels and motor!
Good guide as ever.
    :thumbsup:
« Reply #2 on: March 29, 2015, 08:21:59 PM »
Yes,  I think it was a different generation to yours! Shame I didn't have this done when that person had issues before Christmas!
Sold earlier,  new owner seemed very happy with it!
Offline autovac01
  • Woman in a man's world.
    • Autovac Worcester
« Reply #3 on: May 08, 2015, 02:51:13 PM »
 :bow:
Taking one apart now because the owner has washed the cyclone, brought it in wet and smelly  ::)
Offline autovac01
    • Autovac Worcester
« Reply #4 on: May 12, 2015, 09:46:12 AM »
How the flip do you get the cyclone back together  :'(
« Reply #5 on: May 12, 2015, 10:25:44 AM »
Iirc it was cone into the top cap, then squarely snap the assembly back into the cyclone housing
« Reply #6 on: May 12, 2015, 02:04:23 PM »
Can take a bit of giggling  :D
Offline autovac01
    • Autovac Worcester
« Reply #7 on: May 12, 2015, 02:53:15 PM »
You're not kidding!
« Reply #8 on: May 12, 2015, 07:58:13 PM »
Im surprised at how easy it is to take a cyclone apart tho, it just unclips with a flat blade ;D  clips back in alright, mine never had a satisfactory click tho
« Reply #9 on: May 12, 2015, 08:06:27 PM »
We got a really nice one of these today off an old couple. Original tools, and one careful owner.  :chuckle:
It seems a shame to break it really, but it has reached that stage where DC05's are worth more in bits.
« Reply #10 on: May 12, 2015, 08:17:58 PM »
I'm sure your keeping an eye out for a minter to add to the collection...
So many fade though nowadays
« Reply #11 on: May 12, 2015, 08:28:15 PM »
Mine wasn't too faded, was a malaysian one tho and was still clumsy and burnt out after 2 months in my house, lol but its a good vacuum when its working. The most reliable Dyson cylinder I had was the DC08 Origin. Very robust and very powerful. I have found a nice DC21 for sale locally for £55, Whats the performance of that like against a DC25? The brushbars look similar and the DC25 has excellent edge cleaning cos of one MASSIVE gap on the corner of the head which is hat the DC21 has too, lol.
« Reply #12 on: May 12, 2015, 08:28:57 PM »
I want a nice malaysian yellow and grey one, or a common coloured DC05 cos when they break they take the mick lol
« Reply #13 on: May 12, 2015, 09:26:29 PM »
Only because I got the new green DC05 recently is the reason I am not minting the one up that we got today. I think I'll have to settle for one of each type rather than every variant of every type. We dont have 2000 sq feet spare.  :grinn:
Problem is, a good cable rewind, banana, three tools, used motor, bin insert, expanding pole, cleaner head and a motor bucket for a Panasonic conversion, makes it worth more in bits than I could probably get for it.
