Author Topic: DC03 Clear - Stripdown and Refurb  (Read 37389 times)
« on: April 17, 2015, 09:41:55 PM »
9am - I had a rolly and checked ebay. Nothing
10am -  Rolly time again, checked ebay again for reasons unknown and Boom, there she was!
Advertised for spares/repairs, in storage for 15 years, new cyclone unit 6 years ago and currently dead. £9.99 BIN.
10.04am - I owned a DC03 Clear!
4pm came, and I drove over for 4.30. Home by 5.20 thanks to some stupid  :censored:mazda 6 on the twisties doing 25mph because theres a corner...
To be fair to the seller he turned it over and pointed this out straight away, the centre part of the baseplate is missing. I  assured him this was not an issue  :thumbsup:
Because I'm hopeful that someone we all know and love has one he would be prepared to sell... :bow:
This highlights another issue, the wheel axle has gone rusty, staining the lower motor cover. I've seen new ones on q know who, BUT, that would mean loosing/moving the ratings sticker over and I doubt that would go well so may well tidy this up but leave it slightly stained...
Cyclone is indeed bob new! Has signs of VERY brief use. I will use this more before I refurb it, then probably not use it at all afterwards!
So, all this being brilliant and all, it was indeed dead. I started at the switch, and after 10 minutes of painstaking levering, I cracked the chassis very very slightly, and the switch came out. The contacts were green and it didnt click when pressed. It's a 4 pole switch though (need one of those too, more urgently tbh), so I cut up some cable I chopped off a 1981 Electrolux above some damage, and bridged the cables (as I can't just go crimping new spades onto the end so they plug into each other as you can see it!)
Suction is much better than my DC03 Absolute+, and it highlighted a blockage in the wand! Blockage removed it was fine! I think the belts need replacing though!
This will be a tough refurb, as I'll have to polish the blody inside as much as the outside! Hey ho...
Re: DC03 Clear - Stripdown and Refurb
« Reply #1 on: April 17, 2015, 09:55:32 PM »
I have one of these they are lovely, but can be so fragile, I hope "you know who" has a base plate, I was very lucky and found a complete new one on ebay but it cost about £15.00  I think these perform exceptionally well given the tiny motor.
« Reply #2 on: April 17, 2015, 11:36:20 PM »
I just checked three suppliers, none have that baseplate. I can try two more on Monday. I'll also look in our DC03 stuff just in case we do.
Edit: Q have them, part number 900196-02
« Reply #3 on: April 18, 2015, 12:09:19 AM »
Holy cow so they do! Feel free to ask about but I'll probably just add that to my next order, unless I need any more bits which you can get!
Amazing how parts supplies drop off the face of the earth isn't it! Can't find much new dc03 stuff nowadays I've found
« Reply #4 on: April 18, 2015, 12:56:07 AM »
We bought a stack of wands and brushrolls today. Still have new motors and clutches. I am planning to refurb my silver/white DC03 I recently came by soon.  8)
« Reply #5 on: April 21, 2015, 05:20:18 PM »
Having a bit of an issue with the switch...
The switch I removed (as it's broken) has 4 connectors, both the L and N connect to the switch. However, I cannot find a 4 pole switch anywhere, just 2 pole ones. Of course, I could get a 2 pole switch and wire the neutral together as per my other DC03 (and every other one by the looks of it), but that sounds like a cop-out...
Anyone got a 4 terminal dyson switch they would sell?
« Reply #6 on: April 21, 2015, 05:55:31 PM »
Loads of them.
 ;D
« Reply #7 on: April 21, 2015, 06:17:30 PM »
Brill, will be in touch when I have some spare change then! The bits of wire bridging the terminals can stay put for now!
« Reply #8 on: November 09, 2015, 08:19:51 PM »
Apologies for the lack of updates on this, but TBH I have not done much myself!
One thing that happened shortly after I got it is the broken handle fully went
Didnt really surprise me, and I glued it up
I have bought (well, reserved, yet to pay for it) a non broken DC03 Clear wand (thanks richieg), so I'll keep this broken wand for storage, and keep the unbroken one for display use!
Saturday morning, I was up in the loft doing something else and bought it down with me
The wand went straight on the sofa, not going to do anything with that
Cyclone off
These pictures highlight what a pain this stripdown was, the see through plastic either didn't focus or bounced the flash back...
Either way, there is a screw under the switch cover. I didnt put the switch cover back on after replacing the switch so I didnt have to battle it off again. It is now temporarily mislaid... :censored:
The little switch housing lifts up and out
Cable off
Empty
The side handle is held in at the top by this peice of moulding being held in by the switch housing, so the handle goes all floppy at this point
The removeable suction channel part comes out next, was a bit bendy getting it out
Seal removed
Tools off
Hose out
Hose removed from the changeover valve
Pivot part removed from the housing
Split down some more (no idea what these parts are called tbh)
These were hiding inside the hose
Seal pulls out
Pivot seal out
Hose locking tab and spring removed
Back to the main machine now, and nestled inside the suction channel is a screw
This releases the tool holder, pre motor filter and pre motor filter housing
This is the non washable one, needs replacing, it's minging
The locking mechanism splits down
The top handle looks easily breakable
So it and the little seal are removed
I took the post motor filter out, which is also in need of replacement
Time to move down
The little inspection window did this whilst removing it, which isnt a massive issue as you will see later
The baseplate is borrowed from my Absolute+ DC03
it can have it back now
The belt lifter tool is very tricky to use on a dc03 as it doesnt sit right, and the tab of the clutch housing it sits on is damn fragile, so gingerly I wrestled the brushroll out
and split it apart
Baseplate seals out
The LHS rear wheel comes off now
and onto plastic casualty number 1, this thread snapped whilst removing the clutch cover screws
I re-belted the clutch when I first got it as the ones in it were so stretched the brushroll barely turned, so that's one job I havent got to do now!
The other rear wheel comes off
The cleanerhead lifts off now, and reveals plastic casualty number 2
Cleanerhead removed, it's off with the bumper
Little window seal out, which broke but I'm not too fussed about that
One of the base plate retaining brackets is screwed in
This little chap pops out of the brushroll housing (no idea what it is tbh)
Plastic catastrophe number 3 (pretty sure I didnt do this though)
Tiny crack on the other side too
Lower motor cover off now
Seal out (which was pointless as you will see)
Reference shot for the motor wires
Neutral wire connects on the other side
Crap shot but the motor is immaculate
spotless!
Motor seals and suction channel
Removing the suction channel releases the post filter holder too
which allows the spinal cord to come out
There's a seal hiding at the bottom
One up by where the cyclone meets the chassis
and naked!
Cyclone now
Lower part split
The cyclone release clip pops off the top
The seal needs removing
An screw
This enables the inner cyclone bits to be pulled free
The cyclone bin seal pulls out of the top part
The release valve sits under the clear plastic hat
A seal holds it all together
The shroud pops off the cone
Everything was then washed and put for drying.
« Reply #9 on: November 09, 2015, 10:40:00 PM »
You still looking for a sole plate?
[Outdated link removed]
« Reply #10 on: November 09, 2015, 10:54:54 PM »
Nope,  got that covered! Should have had the back together bit written uo now but Amy did the asda shop and now we are in bed,  but I got a new soleplate months ago that now finally has a purpose in life -  to sit on this and never get used!
« Reply #11 on: November 09, 2015, 11:02:39 PM »
OK cool  :thumbsup:
« Reply #12 on: November 10, 2015, 12:24:37 AM »
Excellent  thread so far! :thumbsup; I remember when we had our DC03 in 2006ish we got it cheap, £6 (a bit like getting a DC24/25 for £6 today as it was 9 years in production) ;D It was pretty crap sadly, only good for surface dirt and dust on carpets only. Was pathetic on hard floors cos nothing was picked up, I remember vacuuming up some spilled cornflakes off tile flooring and it never sucked any of it up. Also, the hose suction was so bad, I remember picking something up and it was just weak so the thing rattled in the middle tubing.This thread brought back some memories ;D Thanks! I am now on the hunt for a DC03 Absolute+ or Standard and a DC01 Standard  ;) 8)
Offline Tech12
« Reply #13 on: November 10, 2015, 05:41:55 AM »
Hi Sam: The switch your looking for is a 2 pole, 4 terminal switch. Not a 4 pole switch.
« Reply #14 on: November 10, 2015, 06:25:45 AM »
Aaah Mvacs sent me a switch months ago! I just didnt refit the switch cover so I wouldnt have to take it apart again.
