Author Topic: Dyson DC14 hot  (Read 7121 times)
Dyson DC14 hot
« on: July 16, 2015, 08:13:30 pm »
Hi guys, recently I noticed that my DC14 Animal switch housing was getting hot in use, not by the switch but about an inch away so I presumed it wasn't the switch at fault.
 Then, it often went intermittent for no reason, I even wiggled the cable and the vacuum didn't cut out, just cut out randomly on one occasion.
Today, I noticed a spark when I switched the machine off, like a blue  flash, not by the switch but I could see from the translucent purple switch that it was at the bottom of the housing which was weird? It was on the side too. I got a hammer and gently tapped different parts of the housing, every time I tapped, the flash happened.
Then I hit the switch and it died, no power to the vacuum unless I knocked it again, that is so weird though, the switch presses and clicks fine, when I depressed the switch it came back to life, there are no loose connections either, I was the last one to refurb the machine too :/
To summarise;
Hot switch housing
flashing blue sparks
Intermittent (not the cable)
When switch was depressed it was still dead but took a few presses to get it working again :/
This is the weirdest thing I have ever come across with a Dyson
Re: Dyson DC14 hot
« Reply #1 on: July 16, 2015, 08:49:43 pm »
Your switch is on the way out.
Re: Dyson DC14 hot
« Reply #2 on: July 16, 2015, 08:50:46 pm »
Ill swap you that issue for a dc07 that the switch works fine on,  until you put the switch housing on then it doesnt switch on or off at all...
Does the switch still make a nice clicky noise (unplugged obv)  or is there no definition between on and off?
Re: Dyson DC14 hot
« Reply #3 on: July 16, 2015, 10:02:04 pm »
The switch seems normal and it makes the healthy clicks when unplugged, I was a bit confused though because the housing was quite warm, closer to the cyclone catch than the power switch :/
Re: Dyson DC14 hot
« Reply #4 on: July 16, 2015, 10:04:20 pm »
Nick a switch from an 02, 03, 04, 05, 07, 14, 15, 24, 25 and try it
Re: Dyson DC14 hot
« Reply #5 on: July 16, 2015, 10:07:21 pm »
Will do :) Actually my DC40 has 2 ;D
Offline Tech12
Re: Dyson DC14 hot
« Reply #6 on: July 17, 2015, 08:59:16 am »
Is the switch housing warped ?.
Re: Dyson DC14 hot
« Reply #7 on: July 18, 2015, 09:11:20 am »
I thought that, so grabbed a spare swotch housing.  Was still no better,  its all back in the shed now whilst it thinks about what its done...
Re: Dyson DC14 hot
« Reply #8 on: July 18, 2015, 10:14:25 am »
It died yesterday... So sad I couldn't get it to work as it was a very good machine. 5 mins later...Fixed it! It ain't gonna retire 😃 it was a loose connection of one of the brown wires the switch, weirdly I could have sworn that I was sure that the connections were on properly, lol but yeah I'm glad
Offline Tech12
Re: Dyson DC14 hot
« Reply #9 on: July 18, 2015, 12:47:24 pm »
Not like you to give up, what about the button itself ?.
