Author Topic: How I repair DC04 Hoses  (Read 5277 times)
« on: August 18, 2015, 08:46:48 PM »
I did a DC07 hose repair topic some time back, so here is the DC04 one.
I had occasion to put a DC04 hose back together earlier
As per the 07 one, the remains of the hose have been pulled out of the cuff using the finest* pliers
DO ensure the lower cord hook/clip is on the hose BEFORE you start (found that one out the hard way...)
The removal process is the same too, however you need to hold the cuff in suck a way that you can hold the cuff, screwdriver AND push the bleed valve button in
Voila
The bleed valve button pops off one side of the black ring, allowing removal for cleaning
The locking ring. I opted to leave this the  :censored: alone as it's a HATEFUL bastard if the springs pop out and do one FOREVER
The hose sits on top of the inner part, in an inferior way to the dc07, as it's not clamped externally. So, lashigns of glue, and push/twist until the end of the hose hits the stop. I then drip glue around the top join too.
Push the 2 parts back together and voila
Gonna let the glue set overnight and give it a medium pull test and see if it holds.
Re: How I repair DC04 Hoses
« Reply #1 on: August 18, 2015, 09:40:20 PM »
Quote
Oh yes been there, with spring ricocheting off the wall and the cat  :underchair:
« Reply #2 on: August 18, 2015, 09:41:41 PM »
Its worse in the garden,  they ping off and land silently somewhere...
« Reply #3 on: August 18, 2015, 09:44:44 PM »
There are a few in the house that I have never found to this day
« Reply #4 on: August 19, 2015, 08:38:00 PM »
Lovely guide! I had to run tape over the end, thickly and push it in hard, crap way but worked.
And if something goes missing just vacuum the area and empty it out onto a surface
DC04 Spare Parts
