Author Topic: x2 Dyson DC01 Refurb  (Read 10889 times)
Offline Dyson2000
« on: October 15, 2015, 08:54:36 PM »
So then, I decided to refurb our old hoover, and now is the chance for it to be clean cause I'm off for a fortnight.
Here it is
Cyclone off
T15 bit to remove the screw from the top of the cyclone
I removed the release valves first.
Then the handle bit.
Offline Dyson2000
Re: x2 Dyson DC01 Refurb
« Reply #1 on: October 15, 2015, 09:19:53 PM »
I removed the filter cage from the machine, Bit dirty, I completely for got about them Oops  :'(.
The hose, i all ready removed the wand.
Push that clip
And out it pops.
The Cable and switch, remove this plastic cover, unscrew it with a T15 bit Again.
And i should come off.
Offline Dyson2000
« Reply #2 on: October 15, 2015, 09:24:17 PM »
Now Removing the switch and cable.
Unscrew the wires on the block connector
Then pull out the switch and unhook the wires.
Unscrew those metal cable holders (T15) And the cable should be free to pull out the hole. i left this rubber piece on the body.
Removing the Filter Cover.
Out it pops.
Offline Dyson2000
« Reply #3 on: October 15, 2015, 09:30:56 PM »
The Sole Plate
Removed the 3 Screws holding it in place.
Its off.
Removed the Brush bar and belt.
The wheels. uncliped the yellow plastic cap both sides.
Removed this Metal clip holding the wheels in place.
And the wheels are off.
Offline Dyson2000
« Reply #4 on: October 15, 2015, 09:38:41 PM »
The Kickplate.
Uncliped from one side and then the other.
And its off.
Removing the motor. Remove 6 screws from the bottom. to get at the motor
And the bottom bit is now off.
Take note where those wires go.
And its Free!
Offline Dyson2000
« Reply #5 on: October 15, 2015, 09:44:03 PM »
Tidied the motor all up.
Lubed the brush bar. it will need a new one shortly. the bearings are almost shot. cleaned up the rest of the parts and are left sit to dry for tomorrow.
Then My Nan's hoover arrives. So i had a closer look!.
Oh. :o
Filters are not too bad.
Will do this one Tomrrow. and put our one back together. ;)
« Reply #6 on: October 15, 2015, 10:25:24 PM »
 :o fixed sole plate, rare  :thumbsup:
« Reply #7 on: October 15, 2015, 10:37:50 PM »
Very nice! That brushroll does look nearly dead, but easy enough to swap over whenever!
A little hack I do is to not put the cyclone release valves back in and cut some insulation tape to stick over them within the square moulding. Takes a few bits and a few minutes, but it really improves the suction! Valves can be put back in whenever for originality.
Offline Dyson2000
« Reply #8 on: October 15, 2015, 10:48:56 PM »
Yep. I'm going to do that for the both of them. Bye the way I've got a purple cable for that DC01 Dejstill
« Reply #9 on: October 16, 2015, 12:51:55 AM »
Lovely! I want a DC01 now, lol. My favourite is the VERY latest DC01, as I grew up with that one ;D YDK motor like your one, red cyclone stickers and the current Dyson logo. Everybody knew how to maintain a Dc01 back in the day :) I hate fitting a hose to one of these though, so stubborn
Offline Dyson2000
« Reply #10 on: October 16, 2015, 02:46:29 AM »
I think my Nan's is a late one as well with the first swivel  soleplate. Our one looked exactly the same as that but with a fixed sole plate. I like the motor in our hoover.  The suction without the release valves been taken out and covered is unreal. I wonder what it is going to be like with them covered!  :coffee:
Offline Dyson2000
« Reply #11 on: October 16, 2015, 02:48:05 AM »
Yep. Also I think they are wurth £30
« Reply #12 on: October 16, 2015, 10:53:25 AM »
I noticed that if you cover the DC04 release valve with sellotape it has better suction too :)
« Reply #13 on: October 16, 2015, 10:54:26 AM »
PS I like that carpet, it brings back memories of the rental house we have, that was the same carpet there I think back in 2007
Offline Dyson2000
« Reply #14 on: October 16, 2015, 07:28:58 PM »
Striped her down at Lunch time. First Took off the cyclone.
Now taking off the Sole plate and Brush bar, Belt.
 :o
That's That Off!
The hose. Removed the wand and pushed this clip.
DC01 Spare Parts
