Author Topic: dC25 Roller Not Spinning  (Read 5771 times)
Offline ramanm
« on: November 17, 2015, 03:04:52 pm »
How can I determine which is the problem if the roller does not spin, even when the switch is pressed on. How do I know if the motor is OK, please?
Offline Tech12
Re: dC25 Roller Not Spinning
« Reply #1 on: November 17, 2015, 05:32:37 pm »
Hi & welcome to the forum, 2 questions: 1) What country are you in ?  2) Do you have a multimeter and feel confident using it ?.
« Reply #2 on: November 17, 2015, 05:36:51 pm »
First, you check the yolk loom
https://manchestervacs.co.uk/Dyson/DC25-spare-parts.html/DC25-PCB-Assembly
and replace it as so if it's broken
https://manchestervacs.co.uk/DysonForum/index.php/topic,1670.0.html
If still no luck:
You take the brushroll assembly off the machine, unscrew all the screws underneath bar the 3 at the front (they just hold the front bumper on) and remove the top grey housing. Then you unplug the white and black wires (1 plug) from the pcb, and re-connect the brushroll assembly to the machine. Then you grab a multimeter, recline the machine and turn it on (so it's in the position it should be when vacuuming) and measure the voltage across the motor out pins and report back. If no voltage, jab the brushroll on/off swithc a few times (the reset button is hidden under it). If still no voltage, you need one of these
which fits like so
https://manchestervacs.co.uk/DysonForum/index.php/topic,1942.0.html
which also shows the troubleshooting (you dont need to unplug the wires, even easier!) for the PCB
Good luck!
« Reply #3 on: November 17, 2015, 11:40:04 pm »
He is coming out of California, US, 120v land.
We assume he is not a native English speaker as Claire edited the OP for grammar, case and manners.
If he comes back and confirms he is alive, and coherent, we can help him more.
Offline Tech12
« Reply #4 on: November 18, 2015, 06:57:53 am »
Cheers Stu: I looked at his profile but as with a lot of people, there's no info.
