Author Topic: Hoover 262 - Stripdown and Refurb  (Read 12661 times)
« on: February 07, 2016, 07:25:48 PM »
I've had this for years! I found it on ebay 5 minutes from work and bought it! When I first got it, it didn't run so well
The pictures start in 2013
Dust
It was clean underneath
Ah
Pure filth underneath the hood
The original cable was perished from the handle bail to the motor
so I removed it
I replaced the wires, and refitted the old shielding
Removed the motor
It slowed down when using it I seem to remember
Fan off
Fancase bearing was looking grubby
Coil and Armature even more so!
Some wiring reference shot
Rubbish picture, but the coil was under a thick layer of greasy dirt. I was amazed it ran at all...
Cleaned that off
Cleaned the motor housing out a bit
refitted the coil
and the armature
The carbon brushes are a bit worn though. No more pictures from the past, I put it all back together and it ran well, then I just forgot about it for the last few years.
Until last week!!
When I got it down from the loft! I forgot to mention it had all the original tools and tool holder and airtight hose!
I started on the tools
A small oblong dusting brush
A small round dusting brush
A long wooden wall/floor brush
Crevice tool
Blowing adaptor
This is the adaptor that connects to the machine
The adaptor can be taken off the end of the hose
The cardboard holder is immaculate as well
Extension tube and bent end
and hose
I cleaned the tool caddy off
which made it quite damp but it dried out very quickly
I got some tools out
and started unscrewing the brushes
Dusting brush
Lovely detail on the bakelite
The larger dusting brush does the same thing
and finally the larger, wooden brush
And the tools were disassembled
Onto the machine itself now
Bag removed from the top hook
The bag (and blower attachment) is held on with 2 thumb screws
It's been a few years since I cleaned the bag out
Sadly the bolt that holds the bag onto the collar is rounded full off
I left it alone. Couldnt cut a new screwdriver slot as I would cut the bag, much pressure with the screwdriver as was either rounded it off a bit more, or slipped off towards the bag...
I left it alone and went back to the top of the handle
Switch housing screws removed
and the cover is removed
Switch wiring reference shot
The paint put on by Hoover to denote something is still present
The mains cable earths to the handle behind the switch
The top bag hook is held in by a screw
and lifts out once the screw is removed
The handle is held in with the usual Hoover bolt at the bottom
I do like this design, no having to remove cables to remove the handle like the junior/senior
To remove the plug, a fibre pin has to be tapped out
The plug and handle cables can be withdrawn. Thankfully the wires are immaculate so don't need replacing
It's seen a Hoover service at some point in its past too. I removed the sticker as it was pretty much gone anyway
Getting there now! (joking, another 115 pictures to go...)
I found the serial number stamp
https://lh3.googleusercontent.com/-irxM0R_CFKo/VqUlhcXQdwI/AAAAAAAAxKU/BsrJY9B1po8/s800-Ic42/upload_-1.jpg
and removed the baseplate
Agitator out
brushroll end caps off
Yummy
The brushroll bearings were  :dead-dyson:
fished out the wobble washers
and the same on the other side
With some considerable fiddling the brushroll end caps came out and the brushroll was sick everywhere
The brush strips were knackered too, they had gone very soft and sparse
Back to the machine, the rear wheels are held in place with this bolt
The whole thing is sprung, as it is part of the mechanism that locks the tool adapter in place. A dyson brushroll axle came in handy to tap the axle out
Once removed,  the wheels came off
and the springs and bracket for the aformentioned tool adapter fall off too
Onto the tool adapter chute now
It has a little flap that does a shit job of keeping the suction to the floor when the tools are not in use, held in with a small spring
I did try to remove the front wheels but just could not get the circlips off, and realised that even if I did get them off, I may not get them back on again
Underneath done, the hood can come off
revealing the motor
The yolk to motor wire runs through the bottom of the handle
There is a slight interlude now for the tools, which were dry and could be polished
Back to the machine, and the metal brackets that form something to do with the dirtfinder can be removed from the hood
The bolt holding the handle bail together can be removed
The socket is held in with a screw
and the handle can be withdrawn, and the wiring disconnected
The spring that keeps the handle sprung falls out at some point around here too
Quick shot of how the wiring attaches to the socket inside the handle
and the handle bail is removed and stripped
The handle release pedal is held in place with a small bar which is easily tapped out
I started taking the bag holder bolts out, but only one side could be removed
The other side is blocked in with the chassis moulding, and I could get a spanner to it but not turn it, so I left it be!
The motor is next, and I took it apart out of sequence, only having a brainwave when re-assembling it so ignore these pictures for now, I took better ones on re-assembly...
4 screws release the motor, and the belt spindle has to come off first
Then the fan can be lifted off
revealing the fancase bearing
tiny carbons out at this stage
I took the bearing out first, which was a bit stupid as the nuts fell into the motor...
Then the bearing holder (which I should have done first...)
Motor wiring removed
(again, what should have been the second step) is to unscrew the top cover of the motor
The small fan that cools the bulb unscrews next, then the armature can be withdrawn. The coil needs its connections unscrewing now
Then the brush holders removed
and she is stripped!
Re: Hoover 262 - Stripdown and Refurb
« Reply #1 on: February 07, 2016, 07:26:00 PM »
Whilst I washed, dried and polished it, a fellow collector sold me 2 new bulbs and some new, much stiffer brushes
The hood also polished up really really well!Nearly 80 years of muck just vanished
And it's on to the motor re-assembly, done in the correct order this time!
Brush guides back in
Whilst trying to refit the coil, I noticed that one side of it had the connector broken off, so wasn't actually connected to the carbon brushes one side at all... still ran fine though!
A new ring terminal crimped and heatshrunk on soon had that sorted, and the coil could be fitted
I re-did the terminal on the other side too as it was looking a bit thin
That done, it's time to build the armature up. Fit the bearing to the holder, and fit that to the armature
Then drop the fan spacers and fan onto that
and fit the belt pulley (could do with a new one of these for it too, it's a bit worn)
Drop the assembled armature into the motor, screw the little cooling fan onto the top and fit and screw down the top bearing, and fit the carbon brushes
The motor can be refitted to the machine now. There was a rubber seal originally, but this fell apart when I removed it so I fitted the motor back after running a nice bead of black sealent around it, which will do a much better job than the old rubber seal anyway
Quick test before I sealed it down
Lovely!
The release pedal can be refitted now
I tidied up the motor wires with some solder
and fitted that and the handle bail back together
Re-fitted the bag holding bolt I removed
Refitted all the springs and rear axle (which isnt actually too bad as the springs hold themselves in whilst you fiddle with the axle)
Lashings of grease was used with that bit too to smooth it out
I did a stage 1 polish on the hood, still need to get the machine polisher on it
and moved onto the handle, re-fitting the wiring
Brushroll now
Swapped the rubber feet from the old brushes to the new ones
Sadly the new brushes are not genuine, but the fact that they actually contribute to the 'It Beats, as it Sweeps, as it Cleans' action now, I wont hold it against them!
fitted
2 shiney new brushroll bearings were procured
but it was too late to tap the end caps in to fit it all together by this point, so I put the metal bracket into the hood
and got a bulb out
Not being a qualified person in anything, I ignored it's advice and fitted it anyway
and with that, the hood can go back on
as can the bag
and she looks like a Hoover again
Sadly the bag does have a bit of damage, which has been made worse by someone covering it in gaffa tape at some time in the 1980's
and there is some wear at the top where the bag slide goes
but, it still looks bloody nice! Daylight came at the weekend, so I could tap the brushroll end caps home, and fit the brushroll
Sadly one of the end caps doesn't fit 100% correctly, but the brushroll is still balanced and silent
Baseplate back on
The handle needs re painting, which I would like to have a crack at when the weather improves, as I would be a single man if I attempted to do that in the front room
I then had a good play
and gummed the crap out of it, all the hair wrapped around the brushroll and forced the belt off, slowing the motor. I paused the video to sort it out, but my phone went into stand by and stopped the video, so I had to make a part 2, and stuck to some nice easy dust which really shows the agitation off
This meant that I had to clean the bag
The micro hose for the Miele was excellent for it
50/50
Eva modelled it for me once it was clean
There was one final job to do though. Ever since I took it apart the first time, I forgot to refit the bolt that holds the tool adapter clamp on. I found it in the shed
and fitted it
This meant I could have a go with the tools, which are laughable tbh but the hose is airtight after checking on the miele
and for now, she is done! Need to paint the handle at some point in the summer and job jobbed! I'm really pleased with how it turned out. Now I just need a bojack bag so I can use her a bit, don't want to keep making the original bag dirty...
Offline RustySkull
  • Kirby, Royal, Sebo =)
« Reply #2 on: February 07, 2016, 09:33:05 PM »
Blimey, long thread, nice job though ;)
« Reply #3 on: February 07, 2016, 09:42:29 PM »
long? that wasnt a long thread!
thanks though.  need to watch your kirby videos tomorrow
« Reply #4 on: February 08, 2016, 01:24:41 AM »
Nice pen in one of those photos.  ;D
Yes, that handle needs painting and the missing front lense needs finding.
But nice machine. And a thorough job as always.  :thumbsup:
« Reply #5 on: February 08, 2016, 06:42:11 AM »
ah,  theres no missing front lens,  it didnt have one full stop! this is  a pre war design,  inface this is one of the models that got caught up when production stopped.  This example is post war,  due to the mottled balekite hood or summat, pre war ones were solid colour.
But its not designed to have a bulb lens.  The way the motor cools the bulb is quite cool though
« Reply #6 on: February 08, 2016, 10:44:12 AM »
Very nice, I just love the design, reminds me of something from a black and white sifi movie.  I really want one, as much as I want a Hoover Starlight.
« Reply #7 on: February 08, 2016, 11:04:44 AM »
I got lucky with mine, happened upon it on ebay as so many ace finds are!
« Reply #8 on: February 08, 2016, 05:20:31 PM »
You will be wanting this then.
« Reply #9 on: February 08, 2016, 06:14:07 PM »
Bootiful! How much is 22gns nowadays? What is gns? Guinea?
« Reply #10 on: February 08, 2016, 06:20:16 PM »
A Guinea I recall from horse auctions years ago is 1.05. 23 was a lot in 1938.
« Reply #11 on: February 08, 2016, 06:26:13 PM »
Wow, the closest I can get is:
In 1935, 23 0s 0d would have the same spending worth of 2005's 850.54
http://www.nationalarchives.gov.uk/currency/results.asp#mid
That's nearly a Kirby!
Wish it was worth 850 today!
« Reply #12 on: February 09, 2016, 10:03:49 AM »
Pedant's corner: one guinea was (strictly) 21 shillings.
Offline dysondc16
« Reply #13 on: February 09, 2016, 09:55:37 PM »
Wonderful refurb as usual! Very lucky to have the tools and all, most hoses from that era have long since degraded.
Poor thing, first its brush clogs then you can hear its bag clogging in the second video! May not be the best for a daily driver...
« Reply #14 on: February 09, 2016, 11:35:02 PM »
I dunno,  most machines of its type dont like big clumps of your girlfriends hair,  it all went under the belt and lifted it up and threw it off the spindle!
I have had a plan for the bag,  its a bit heath robinson but it may just work! Shes back up in the loft for now though to stop Eva playing with it,  so it can wait for another day!
