Author Topic: DC40 Not Picking Up Properly  (Read 6839 times)
Online oldmoley
« on: February 17, 2016, 11:48:47 PM »
I've just been asked by a friend to look at her DC40, which is not picking up, particularly light dust and animal hairs. Everything seems to be working OK - there is plenty of suction at the hose, and the brush bar is turning. Are there any known problem areas, or parts of the cleaner that are susceptible to blocking? This will be the first DC40 I've worked on; I'm more familiar with the DC04, 07 and 14 ranges.
Hoping someone can help.
Re: DC40 Not Picking Up Properly
« Reply #1 on: February 17, 2016, 11:56:21 PM »
tayyab to the curtosey phone!
Online __russ__
« Reply #2 on: February 18, 2016, 12:11:30 AM »
Have you tried unclipping the cleanerhead and checking the pipe and hose behind it for blockages?
Online oldmoley
« Reply #3 on: February 18, 2016, 01:50:38 PM »
Hi Russ. Thanks for your reply. Just had everything apart, and not a blockage to be seen! I'm wondering whether there may be a split in one of the internal hoses (nothing obvious to be seen at the moment), or whether the cyclone might be blocked. Is it possible to remove the cyclone?
« Reply #4 on: February 18, 2016, 01:54:52 PM »
You can remove the cyclone (take it off as if to empty it). Then turn it on whilst removed, and check the suction coming out of the chassis from the motor is nice and strong. If so, your problem is cyclone and beyond. You should hear a difference in motor tone too.
Then, refit the cyclone whilst the machine is running, and you again should hear the pitch change.
Empty the cyclone and check the filter is clean, and try again. If still blocked, your issue is past the cyclone, and indicates a blockage. I've not had a DC40 so cannot comment as to their common issues!
« Reply #5 on: February 18, 2016, 01:56:33 PM »
Hi
I had a Dc40, I would recommend you take the cleaner head off bu taking the red clip off (from underneath) and remove the head.
Then turn the vacuum on and recline it. Is the suction at the front of the vacuum the same as the hose suction? If so, the head is at fault somewhere... Maybe the active base plate has ripped or the soleplate isn't fitted correctly.
If the suction isn't the same at the base as the hose, then I would inspect the tiny hose inside the ball at the back of the vacuum. Remove it  (just pulls out) and check for any blockages
« Reply #6 on: February 18, 2016, 01:58:12 PM »
PS underneath the bin there is a clear tiny window, flip that up open and check that for blockages too
Online oldmoley
« Reply #7 on: February 18, 2016, 02:28:12 PM »
Thanks everyone for your helpful comments - have the accursed thing apart at the moment, so will report findings shortly!
Online oldmoley
« Reply #8 on: February 19, 2016, 12:03:04 AM »
Just returned the DC40 to a happy owner. There were no obvious blockages as such, but there was a lot of dust and debris in the cyclone. Probably not enough to have been the only cause of the problem though. I removed the head and stripped and cleaned the assembly, together with the brush bars. Re-assembled, and problem solved! Now enough suction to lift the carpet from the floor.
Once again, many thanks to all who commented. I'm not quite such a DC40 virgin now.......
« Reply #9 on: February 19, 2016, 02:02:51 AM »
Brilliant! Glad it is working :)
Offline RustySkull
  • Kirby, Royal, Sebo =)
« Reply #10 on: February 19, 2016, 09:31:03 AM »
I was going to say it's all about checking everything... There are only so many air paths and if they're all clear there can be no blockage ;)
Glad it's alive again ;)
