Author Topic: Dyson DC07 Relief Valve Problem.  (Read 13392 times)
Offline rob_520
« on: March 09, 2016, 06:47:47 PM »
why has the release valve stopped working on the side it wont oped when you block the hose ... all filters have been change no blocks in the pipes any ideas ?????
Re: Dyson DC07 Relief Valve Problem.
« Reply #1 on: March 09, 2016, 07:47:57 PM »
It wants stripping and cleaning.
Offline RustySkull
  • Kirby, Royal, Sebo =)
« Reply #2 on: March 09, 2016, 07:49:23 PM »
Yeah a good clean out would benefit it no end dude!
Offline rob_520
« Reply #3 on: March 09, 2016, 08:00:38 PM »
its been totally stripped  and deep cleaned inside and out all filters replaced all airways have been fully cleaned and still wont open the valve when you hold your hand over the hose so I am stumped but thanks for your answers
« Reply #4 on: March 09, 2016, 08:35:09 PM »
No, the valve wants stripping and cleaning.
Offline rob_520
« Reply #5 on: March 09, 2016, 08:46:29 PM »
well ive done that and cleaned the valve ... ive tried it on another machine and it works .its doing my head in can't understand it it should work but don't but thanks for all your answers keep them coming just incase ive missed something many thanks
Offline RustySkull
« Reply #6 on: March 09, 2016, 08:53:52 PM »
Okey,so let's step back and take a recap here... You've stripped and cleaned the whole unit, and also stripped and cleaned the Valve.
Then, you tried the valve on another unit and it works as it should, but back on the original machine and it's not working.
Have you checked for obstructions stopping it from opening? Such as a small bit of debris, perhaps it's not fitted quite right?
Have you done the opposite and tried the working Valve from the unit you tried this one in, on the original unit? Does that work?
I'll await your reply while sipping Whiskey and sitting in my arm chair.   :reading:
Offline rob_520
« Reply #7 on: March 09, 2016, 09:25:36 PM »
yes i've done all that .all what you said I removed the valve spring the the black top piece that sits inside cleaned all that .put it on another machine and it works fine .I checked for piece of grit dust etc. I made sure that the black rubber ring is fitted inside. I even changed the motor house cover just incase the rubber was not sealing and no difference .ive checked all the other seal and changed them from a working machine still the valve wont open .and of course if that don't work it will burn the motor out in time .so hence I'm really scratching my head and fingers are soare lol many thanks for all your help
« Reply #8 on: March 09, 2016, 09:34:52 PM »
Could the machine be sucking air from somewhere else?
Offline rob_520
« Reply #9 on: March 09, 2016, 09:38:52 PM »
ive even tried different hoses p tube u ends still the same checked everywhere for leaks nothing I can find
« Reply #10 on: March 09, 2016, 10:18:31 PM »
Take off the side valve pipe and block the suction with your hand. Does it release the valve easier? If so, the problem is between the u bend and wand. If not, there's probably an issue with the cyclone. Maybe the cyclone seals are worn?
« Reply #11 on: March 09, 2016, 10:32:55 PM »
Is this a dc07 or a dc33???
Offline rob_520
« Reply #12 on: March 09, 2016, 10:45:36 PM »
sorry its a 07
« Reply #13 on: March 09, 2016, 10:52:37 PM »
OK thanks.
There are no seals in the cyclone.  Have you tried swapping the cyclones over?
Offline rob_520
« Reply #14 on: March 09, 2016, 11:09:30 PM »
yes I have tried one from another machine that works fine and still no joy
