Author Topic: dc14 non clutch  (Read 2945 times)
Offline twocheeks
dc14 non clutch
« on: May 28, 2016, 12:06:55 PM »
hi all, new to here, could someone please let me know the size of the bearings in a dc14 non clutch brush bar thanks
Re: dc14 non clutch
« Reply #1 on: May 28, 2016, 07:04:33 PM »
ERM,  the larger of the two you can get. Black band around the middle
But they are fixable if you have seized ones.  Pop them out with the end of the axle.  Pop both plastic caps off the bearing with a small screwdriver,  and scrape out any dry rubbish,  and pick out the hairs.  Fill with grease,  and work it in until the bearing moves.  Keep going! When moving well,  top the grease up,  put the caps back on and refit to the brushroll,  and the brushroll to the machine.  Fire her up a d run for a few mins and hopefully fixed!
I show it in my dc14 refurb thread if that helps,  that had a seized bearing.
Offline twocheeks
Re: dc14 non clutch
« Reply #2 on: May 30, 2016, 09:23:15 AM »
Thanks for the reply beko1987. When i popped the old bearings out and cleaned them up i seen the size on the side 627 2rs. luckily i had an old 04 donor, with good bearings so used them .
Thanks again.
