Author Topic: DC24 main motor arcing and noisy run down  (Read 5128 times)
Offline ianh100
« on: June 24, 2016, 06:23:57 pm »
I have a DC24 that is mostly on good condition but it seems to make strange noises after switching off and the main motor spins down. I notice that if I turn it on the HEPA filter removed I can see quite a significant spark at the brushes as it starts up and quite a lot of sparks at the brushes as it runs. I don't have another here to compare it with.
It is not that noisy when running but makes quite a howl as it spins down. Is it worth (possible) to replace the carbon brushes or do I just get a new motor?
Re: DC24 main motor arcing and noisy run down
« Reply #1 on: June 24, 2016, 08:04:50 pm »
You need a new motor, replacing the brushes is a waist of time and money.
« Reply #2 on: June 25, 2016, 12:22:44 am »
You need a new motor, replacing the brushes is a waste of time and money.
What he said. ^^
