Author Topic: Dyson DC24 hepa - removal of rotating carpet sweeper assembly  (Read 6132 times)
Offline John7691
« on: August 28, 2016, 11:34:11 PM »
Hello, I am a new member from Melbourne Australia.
The rotating brush-gear (carpet-sweeper) on my Dyson DC 24 no longer rotates.
On searching the web I found your site and its helpful videos.  I can work through that process - : clogged, power supply, or motor failure etc.  However, all your videos show the assembly already removed and I'm not sure how this is done.
There is a single screw on the underside but after that?.  I am loath to use any force since the materials are hard plastic and probably intolerant to force.  Do I twist, pull or is there something else that I should do?
HELP!
John
Re: Dyson DC24 hepa - removal of rotating carpet sweeper assembly
« Reply #1 on: August 29, 2016, 11:44:56 AM »
If you mean removing the main cleanerhead from the machine, like so:
Offline John7691
« Reply #2 on: August 30, 2016, 05:18:57 AM »
THANKS!  Looks simple, but I didn't want to use too much force and break something.
I'm away from home at the moment but I'll try this when I get back home at the weekend.
Cheers,
John
Offline John7691
« Reply #3 on: September 03, 2016, 06:58:54 AM »
OK Thanks, Roller Bar successfully off now.   230V AC power supply OK to Roller Assembly.  Roller motor has resistance between terminal leads of > 200 kOhm - Fault to Open Circuit?
I have not checked power supply from pcb.  Is it OK to operate this on no-load?  That is, can I energise it with the 230V DC motor disconnected?
 My thinking is that before I order a replacement motor, I'll check to see if the pcb is also faulty.
Thanks for help so far.
John
« Reply #4 on: September 03, 2016, 08:12:17 AM »
Yes the pcb is fine with no load,  hook the meter up to the pins the motor plugs into,  with the machine on and reclined.  300v rings a bell,  but I'm never 100% sure,  you should see something anyway.
Offline John7691
« Reply #5 on: September 06, 2016, 04:33:08 AM »
With 230V AC to input of pcb, output is 316V DC.  So, I think that pcb is OK.  :tiphat:
With the motor, I have open circuit (>200kOhm) between the brass brush holder ends. Connections to the motor from pcb are OK.
I think that it could possibly be a worn brush, not contacting the commutator properly or simply a burnt-out armature winding.  I'm thinking of removing the brushgear to check brush condition but I suspect that in the end, I'll have to replace the motor as a whole unit. :(
Regards,
John
« Reply #6 on: September 06, 2016, 06:17:34 AM »
You need a motor.
Ours are >here< and are OEM. Beware non OEM ones as some out there are very poor quality.
Offline John7691
« Reply #7 on: September 06, 2016, 07:04:20 AM »
What is OEM?   Is it the manufacturer or a compliance standard?
 My existing motor has a label which says:
JOHNSON
DF651(2)LG
240 V DC
50502200020B
1D60060 CL.B
What sort of delivery time and cost for delivery am I looking at?...  to Melbourne Australia
« Reply #8 on: September 06, 2016, 07:27:45 PM »
OEM - Original Equipment Manufacturer IE a genuine part
« Reply #9 on: September 06, 2016, 07:44:47 PM »
Indeed. You will get a Johnson one.
The site works out delivery during checkout and full delivery info is >here<, but Oz is typically 10-14 days. 21 at a push.  :tiphat:
