Author Topic: Dyson DC08 turbine belt  (Read 3321 times)
Offline twocheeks
« on: September 02, 2016, 10:22:31 am »
Hi, i have a dc08 turbine that sets off at normal speed but if i knock it slows down like its slipping, but if i restart the hoover it runs fine again until i knock it. Is their anywhere i can purchase a new belt thanks.
Re: Dyson DC08 turbine belt
« Reply #1 on: September 02, 2016, 08:56:42 pm »
Check the plastic fan hasnt cracked rather than the belt. If it has,  glue might save you
Offline twocheeks
« Reply #2 on: September 02, 2016, 09:12:51 pm »
Thanks for the reply beko1987. I have had it stripped down and took the fan out and it seemed ok and intact, but the belt felt really loose so put a bit of heat on it to try and tighten it a little which seemed to help as it takes a harder knock now to make it slip, but don't want to go to far as to make it brittle.
