Author Topic: Loss of suction on DC24 Ball  (Read 4954 times)
Offline paulD
« on: October 06, 2016, 04:53:32 PM »
Our DC24 is working fine when brushing carpets and floors but it has lost all suction to the removable handle. The mechanism that seems to switch the power doesn't function properly. Any suggestions out there please?
Re: Loss of suction on DC24 Ball
« Reply #1 on: October 06, 2016, 06:00:34 PM »
Remove the centre screw from the wheel, remove wheel, clean and polish wheel and mounts. This should cure it.
Offline RustySkull
  • Kirby, Royal, Sebo =)
« Reply #2 on: October 06, 2016, 09:08:48 PM »
Clean it all, dirt build up causes all kinds of problems. Just like it would for you if you didn't wash.
Offline paulD
« Reply #3 on: October 07, 2016, 03:08:53 PM »
I appreciate the suggestions and I may be a bit stupid but this is a ball machine. "Remove centre screw from wheel"  ?  Er......what wheel?  Do you mean the ball or the twin rear wheels?
The problem isn't dirt or dust.  It is with the mechanical linkage which engages or disengages when you move the machine to the upright position.
« Reply #4 on: October 07, 2016, 04:44:46 PM »
There is a wheel made of clear plastic that operates the changeover?
Offline paulD
« Reply #5 on: October 07, 2016, 05:04:26 PM »
Well it's not a wheel exactly.  It's a mainly circular clear plastic ring with a straight section coming off it that acts as a guide path for a grey plastic lever.  The lever is moving ok as far as I can see.
« Reply #6 on: October 07, 2016, 06:15:13 PM »
It may move okay but I have always found this method works;
1) Remove the screw and plastic pin from the clear plastic part
2) Remove the clear plastic part by easing it out the plastic grey finger out the iddle.
Give the clear part a thorough wash and/or wipe down, the groove where it slides is where the issue lies. Where the groove has an erected point is the part where the grey arm gets stuck. It would help to lubriucate that area and reassemble it to see if it works.
Offline floridaone
« Reply #7 on: December 12, 2016, 02:15:47 AM »
Offline floridaone
« Reply #8 on: December 12, 2016, 02:18:07 AM »
can you show the "wheel"?
« Reply #9 on: December 12, 2016, 10:57:35 AM »
Pretty sure he means that egg shaped wheel which is a clear plastic piece
