Author Topic: Early cyclone roots  (Read 3135 times)
Offline renault567
Early cyclone roots
« on: October 17, 2016, 09:48:14 PM »
Hi have a very early 2001 dc07 standard to sell and its cyclone roots are clogged up with hair and fluff etc and I cannot clean them out. This means no suction and it makes a loud using sound.
Any ideas, hose on jet with some of this didn't work.
https://www.ypo.co.uk/product/detail/223212
Re: Early cyclone roots
« Reply #1 on: October 18, 2016, 04:18:58 PM »
First, suck out all the cyclones individually with your most powerful vacuum, something like a DC14 or a Henry would be good.
If that doesn't work, let the cyclone soak in hot water and bleach for a few hours so all the dirt just turns to gunk and spills out.
If that doesn't work, get a sink unblocking powder which (BTW you need to wear protective gear with), so justpour that powder into the cyclones and then pour boiling kettle water into thta, it should eliminate any hair etc.
« Reply #2 on: October 18, 2016, 05:16:33 PM »
Or instead of all that, a decent pressure washer.
Offline Elgin
« Reply #3 on: May 28, 2017, 11:38:07 PM »
I know its old but incase it helps someone else who reads this thread:
Ive used a hose with a high pressure handle and mains turned on max - its done loads of DC07's and 14's well
