Author Topic: 1st refurb of a dc25 ball but now its very loud?  (Read 5241 times)
Offline jamesey
« on: November 09, 2016, 06:38:48 pm »
hi ive replaced the suction motor in the ball with a genuine motor but now when i use the dyson i could do with ear plugs on honestly , no idea what could be causing this , it works great and hoovers up fine , the only thing i can think of you know when you screw the motor housing together theres a rubber seal around it , no idea , its my 1st try at one of these so any help would be great thanks :'(
Re: 1st refurb of a dc25 ball but now its very loud?
« Reply #1 on: November 09, 2016, 07:10:46 pm »
Hi, it depends on what kind of noise it is. Also, where did you get the motor from? If it's a used one, it could be dodgy.
Offline jamesey
« Reply #2 on: November 09, 2016, 07:50:48 pm »
yes it was used but looked like new , really i should have tested it before i put it in
« Reply #3 on: November 09, 2016, 07:59:11 pm »
You probably need to replace the motor again I'm afraid
Offline jamesey
« Reply #4 on: November 09, 2016, 08:44:37 pm »
ill wizz it out again and bench run it.before i moan on ebay lol
« Reply #5 on: November 09, 2016, 09:42:03 pm »
You haven't hit or slapped it at all have you?
« Reply #6 on: November 10, 2016, 10:15:29 am »
If you take the ball filter cover off and the filter out, then turn it on, is it a magical wonderous continuous firework display through the grille? Or just a little flash on start up then ok?
Also, whip the brushroll housing off and take the cyclone off then try it, just to rule out any issues with airflow anywhere.
