Author Topic: DC07 Floor Sucking Advice  (Read 2184 times)
Offline quick978
  • Dyson Neewbie
« on: December 05, 2016, 12:34:28 AM »
Hi guys,
I'm quite new to the game and needed some advice.
I've just serviced a DC07 and the suck from the pipe is very strong, but from the floor it is so weak, I have taken the bin off and checked where the bottom vent goes into the bin and it is strong, I have checked the hose underneath and it is intact with no splits, if I wasn't as bald as a coot I would be pulling my hair out!!!
Does anybody have a solution?
Offline taran57
Re: DC07 Floor Sucking Advice
« Reply #1 on: December 05, 2016, 06:31:54 AM »
Did you check the side diverter valve pipe? Sometimes they do not fully engage when you recline the machine. Also would be a good idea to check the seals. Hope this helps.
Offline taran57
« Reply #2 on: December 05, 2016, 06:33:13 AM »
Offline bluebumble485
« Reply #3 on: December 05, 2016, 09:04:54 AM »
hi if done above I would change the flexi hose just because it has no spits don't mean its there I have had them look good or just twist it if you have had it off if not just change they are cheap
