Author Topic: Hoover Turbomaster U5094 - Stripdown and Refurb  (Read 12257 times)
« on: December 30, 2016, 08:46:08 pm »
Hello everyone!I have alot of writeups to do, am a bit behind so here is one from the end of summer, the day after I got the Xantia in fact! A free Turbomaster, which was amazing as I've always wanted one.
The first shot is of it in the boot
and the ratings plate, which dates it to June 1989
It was a bit filthy
But ran rather well, here is the first look/pre refurb video
Not a valid youtube URL
Re: Hoover Turbomaster U5094 - Stripdown and Refurb
« Reply #1 on: December 30, 2016, 08:49:11 pm »
The very first thing I did was have the hose off for washing, which was a bit dirty
but came up lovely after a trip through the washing machine. Then, a few weeks later, I bought the machine in from the cold, and set to work!
The filth was quite something
It's also very much like a Turbopower in many ways, which means the handle comes off with 2 screws at the top
Like so
The wiring is removed by teasing the plastic peg out
and popping the switch out and unplugging it
« Reply #2 on: December 30, 2016, 08:54:23 pm »
This allows the harness to be withdrawn
The top cap of the handle pops off too
It didn't have any small tools when I got it, however a swap with a Premiere Mini and Hoover Junior with youtuber Numatic Collector/Daniel Shanks netted me 3 used tools, and a spare working motor which may come in handy one day, so that was nice
Off they came, and off came the bag door
The air freshener sits behind this little panel here
Or would if it had one fitted
The slider scent control pulls out of the main bag door
The incorrect H18 bag can be removed and binned finally!
Nice little birds nest at the bottom of the housing, dc16 (the vac, not the american dude on here) took care of that!)
« Reply #3 on: December 30, 2016, 09:00:10 pm »
At the back of the machine, inside the carry handle bit are 2 screws which release the wiring cover
There is an inner plastic part too which won't remove without unplugging the bag full light
Once unplugged it falls away easily
and the bag full LED pops out
The bag door release button is held in with a circlip around the plastic prong
Once released it, the spring and the prong fall out
Back to the filthy wiring now, and the suction sensor thing needs to be unplugged
Wiring reference shot
and it's free
« Reply #4 on: December 30, 2016, 09:04:55 pm »
Once de-wired, the sensor pops out of the plastic housing
and the plastic housing is nearly empty
Apart from this sprung part, which is actually what clips the bag door closed, the button removed further up just actuates this part
To remove the plug for the handle wiring, these two tabs need to be popped out
and out it all comes
Now this is different to a TP again, these 4 screws need to be removed to remove the plastic part which holds the bag fill tube
Doing this also releases the mains cable wiring cover/carry handle at the back
So whilst we are here I'll remove the mains cable and choc block
then back inside the bag compartment the clip can be fully withdrawn, after removing the bag fill light suction sensor tube from it
« Reply #5 on: December 30, 2016, 09:08:48 pm »
Nothing holds the bag fill tube in now, so out it comes
It's in two parts on the TM, so I undid the tape and separated it
All down the side of the bag compartment runs some conduit, which carries the spinal cord down the machine
4 screws halfway up the back removes the tool caddy from the back of the machine
and 2 screws on the side of the bag housing removes the hose holder
Looking a  bit barer now!
We now need to work from the bottom up! Baseplate off
This is the belt arrangement, very much like the Vax New Wave (which probably copied this tbh)
« Reply #6 on: December 30, 2016, 09:18:50 pm »
The Activator lifts out and off the small V belt
and splits down very much as usual for one of these
Next, we remove the hood
Then the height adjustment mechanism can come out, and all that fluff was jamming it up in the before video
The plate prises out of the spring clip in the adjuster knob
But that is not all, as on the other side the lens cover has to come off very VERY carefully as they are extinct as spare parts!
This reveals the other part of the adjuster mechanism, which slides over the lens to 'light up' the segments. This was also jammed up with grit and hard to move
This part here seems to seal off the motor from this part of the hood
The bulb was quite dusty too, but worked fine still
« Reply #7 on: December 30, 2016, 09:23:26 pm »
Getting there now. Time to remove the trunnion cover. 2 long and 2 short screws here
Really must look into why IrfanView messes the odd resized image up, but below should show the Trunnion cover removed
We need to seperate the two parts of the cleaner now, but the spinal cord needs removing and unplugging from the motor
Once unplugged and out of the way, the two clamps unscrew and lift off
The two parts will separate now, although this side will need a bit of manouvering as the plastic pivot is nested behind the spring of the brush control, but does come out with a twist and a gentle pull
Once removed, the two pivot bushes pull off
I opted to leave the lower cord hook alone, as they are very rare on a Turbopower 1, let alone a Turbomaster and are a sod to fit, I never get it right!
« Reply #8 on: December 30, 2016, 09:29:14 pm »
Now we can strip down the brush control mechanism. 2 screws and remove the orange cover
With that removed, the black cover and lilac pedal lift away also
The lilac pedal operates a cam on the black part, which in turn moves the spring, so with the pedal in one position, the cam locks the spring in one position, kick the pedal forward, it rotates the cam another turn, releasing the lilac pedal and moving the spring back
This long spring helps here
And this is the spring that moves the belt! An absolute sod to keep in place without the cover, but with the lilac pedal locked in the 'Carpet' position, the spring is released. Locked to the 'hard floor' position, it pushes the spring onto the larger belt, which pushes it onto the non drive part of the 2 belt pulleys we shall look at later! Simple but clever
It pulls out
Onto the other side, and we have the motor clamp
Well, did have. With that removed, the motor lifts out of it's dusty seals
Yet more filth
« Reply #9 on: December 30, 2016, 09:33:26 pm »
Now, sitting next to the motor clamp is a Turbomaster thing called (probably) a Suction Diverter Box. This is what moves the suction from tools to floor, and lifts out easily
This ring sits inside the inlet/outlet part
4 very short screws hold it together
When you move the lever between the modes, it either blocks off the tools and lets the suction run for the brushroll area, or blocks off the brushroll area and lets the suction run to the tools!
The release pedal lifts out of the chassis next
and the Bumper lifts off
Sat on top of the chassis is a metal clamp that holds the belt pulleys in place
With that removed the pulley assembly can come out, bringing the belts with it
« Reply #10 on: December 30, 2016, 09:42:16 pm »
Aha, a Turbopower 1 feature! The front wheels are held in with a spring clip
Remove that, lift the wheels vertical and the keyed pivots pull out of the chassis. The stepper part of the height control lifts out too
The rear wheels remove by popping the tabs at the back of the glamour caps from the back of the wheels and removing the circlips
And the chassis is stripped. Onto the motor now, and the 2 rubber seals can be removed
As can the bellows
People have told me that the TM motors are different to TP ones, as TP ones are 440w, TM is 500w. I think their the same apart from a slight size increase, maybe not even that... Pop the spring clips off that hold the fancase on
Hold a flatblade driver into the belt spindle slot, twist it or the fan anti clockwise whilst holding the fan and the fan comes off
Mark wires now, for reference the red one connects to the coil by the bulb holder
« Reply #11 on: December 30, 2016, 11:31:13 pm »
One thing I like to do on TP motors (and this is a rubbish example) is to score the 2 parts of the housing so it's easier to reassemble correctly
The wiring from the bulb holder clips to the coil on the other side of the motor
and it all pulls off
Undo the 4 screws holding the motor together and it separates, the armature pulling out too
It's a bit fluffy
The top bearing, as per a TP sits under a sprung washer to take up any movement, which all pulls out
I scraped the coil clean
and removed the carbon brushes from the casing
The carbon holders slide out too
« Reply #12 on: December 30, 2016, 11:37:38 pm »
The fancase bearing pops out after removing the clip that holds it down. The video didn't pick it up too well but it may as well have been hexagonal, it was proper crap to spin by hand
The armature bearing wasn't much better either, the puller soon made light work of it
The cooling fan pulls off too
It's a little bit dirty too, that wouldn't have been helping it run true and smooth
Motor stripped, time to look at the 'clutch'. Circlip pliers time
Behind that sits a spacer washer
and another spacer washer which had to be prised out of it's smeggy hole
The two pulleys pull off the shaft, separated by another spacer washer
The driven pulley has a needle roller bearing inside it
« Reply #13 on: December 30, 2016, 11:45:44 pm »
The spacer washers that sit either side of the idler pulley
So that's how it works. The metal pulley carries the V belt from the brushroll, and the spring that's moved by the pedal pushes the belt on or off it. Belt on, brushroll turns. Belt off and onto the idler pulley, no brushroll turney. It's quite sensitive, tall old me pulls the machine up too high in use which moves the belt slightly and knocks the brushroll off...
I greased up the needle roller bearing
and everything was stripped! I washed this little lot
and gave it a brief run over with the machine polisher, although not fantastically as my pads really are falling apart, and I'm very low on polish... Still, it made it 80% better!
Reassembly started in reverse
2 nice new motor bearings were procured, 608's
and the fancase one pushed into the housing nicely
Clip fitted
Carbon holders fitted
Cooling fan refitted to the armature, looking a bit cleaner
and the armature bearing pushed on. Bit of wire wool to clean up the armature shaft and these push on nicely by hand, screwing the motor casing together and maybe a tiny tap with a hammer to center it up pushes it the rest of the way.
« Reply #14 on: December 30, 2016, 11:50:05 pm »
Coil lowered onto the housing
Armature fitted (check that the cooling fan is correctly fitted and doesnt foul on the housing), then fit the top of the housing (again, spin the armature, it should be smooth as silk and not bind)
Very carefully prise the carbon holder caps up, they snap easily
Fit the carbons and lower the caps back down
Fit the spacer washers and fan, again check for smooth spinning
Nice bead of silicone around the fancase (should have been neater but it was going off, so came out a bit crap)
Fit the fancase top and clips, and clean up the ooze
Clutch next
