Author Topic: DC24 needs resetting problem  (Read 10166 times)
Offline twocheeks
« on: January 01, 2017, 10:19:59 am »
Hi, i have a dc 24 that runs good but the reset button keeps popping out every 30 seconds or so, i'm just wondering if it is going to be the motor or pcb.
Offline RustySkull
  • Kirby, Royal, Sebo =)
Re: DC24 needs resetting problem
« Reply #1 on: January 01, 2017, 11:23:20 am »
Are you sure it's not just experiencing resistance?
Offline twocheeks
« Reply #2 on: January 01, 2017, 11:37:31 am »
Thanks for the reply, in what way are meaning resistance? The brushbar is fully cleaned and i have run the hoover with it layed flat on the floor with the head raised off the carpet.
Offline RustySkull
« Reply #3 on: January 01, 2017, 11:55:04 am »
Well, I'd suggest checking the sides of the brush as even wound up hair or carpet fibers can cause enough to cause the trip to reset. That's what it's there for so at least you know it's working I suppose...
Offline twocheeks
« Reply #4 on: January 01, 2017, 12:15:08 pm »
Just been running it without the cover on the head and the motor started smoking then tripped, pressed the reset and it still works surprisingly, but the motor was too hot to handle.
Offline RustySkull
« Reply #5 on: January 01, 2017, 02:18:52 pm »
Well from what you're saying and without seeing it myself it sounds like the motor is working too hard and getting hot thus tripping the trip.
That's common knowledge I'm afraid I can't offer specialized knowledge on that model, I'm sorry to say ;(.
« Reply #6 on: January 01, 2017, 03:35:30 pm »
You need to strip the head and de fluff and clean everything.
Offline twocheeks
« Reply #7 on: January 01, 2017, 03:40:20 pm »
Thanks RustySkull. Hi Madrat the head has been fully stripped and cleaned and the motor cleaned out with a compressor so is spotless.
« Reply #8 on: January 01, 2017, 03:43:18 pm »
In that case if nothing is catching are the belt spindles and brush bar free to turn? the only other thing is the motor itself.
Offline twocheeks
« Reply #9 on: January 01, 2017, 03:52:04 pm »
yeah ive sent it to the  :dead-dyson: and put a spare one in and all is working fine
« Reply #10 on: January 01, 2017, 03:57:08 pm »
There not the strongest or longest lived motors.
« Reply #11 on: January 01, 2017, 04:01:58 pm »
Spray WD40 in all the bearings, just double check they spin freely as Madrat said
Offline RustySkull
« Reply #12 on: January 01, 2017, 04:32:02 pm »
WD40 solves everything, you should all know that by now.
« Reply #13 on: January 01, 2017, 04:36:14 pm »
Yes!!! :icon_nod:
Offline RustySkull
« Reply #14 on: January 01, 2017, 04:39:20 pm »
Especially for you Parwaz, Japan uses a lot of WD40.
