Author Topic: DC27 doesn't recline,  (Read 2973 times)
Offline autovac01
  • Woman in a man's world.
    • Autovac Worcester
« on: January 16, 2017, 11:05:55 AM »
Old posts have mentioned a problem with the changeover valve when the machine is switched on but this one is jammed in an upright position. Any thoughts before I start taking it apart?
Re: DC27 doesn't recline,
« Reply #1 on: January 16, 2017, 03:07:56 PM »
That black lever that you find on DC07/14/27/33s under the cleanerhead, behind the brush housing in the groove of the motor housing and is cured by levering it and spraying WD40 in there and onto the lever's end which has a roller wheel that should do the trick ;)
Offline RustySkull
  • Kirby, Royal, Sebo =)
« Reply #2 on: January 16, 2017, 09:38:19 PM »
WD40 fixes EVERYTHING
