Author Topic: Dyson DC44 Animal battery  (Read 4184 times)
« on: January 17, 2017, 07:00:25 PM »
So I believe the runtime is 20 mins (on normal mode) and 17 mins with a motorised head and then 8 mins on max.
Mine? It got a runtime of about 12 mins on normal mode and 5 secs on max!
Now, mine is the later model because the battery is held in by 2 screws rather than a button
Do you reckon it needs a new battery or motor unit? It has no safety switch for the filter BTW
Thanks ;)
Re: Dyson DC44 Animal battery
« Reply #1 on: January 18, 2017, 07:10:46 PM »
Battery
« Reply #2 on: January 18, 2017, 07:18:18 PM »
Battery
Yep. They are not much cop.
However, check both outputs on the charger first.
« Reply #3 on: January 18, 2017, 07:25:29 PM »
Cheers both
The charger seems to work just like my DC30/34/35 ones I had in the past and the light goes off after a few hours so I presume (going by that) it works flawlessly
Will try a new battery tho thanks :thumbsup:
« Reply #4 on: January 18, 2017, 07:30:39 PM »
That's a point, make sure both outputs are working from charger.
« Reply #5 on: January 18, 2017, 07:35:14 PM »
Dont assume, test both outputs. If one is down it won't charge fully.
« Reply #6 on: January 18, 2017, 08:22:57 PM »
Good point
I'll check that
