Author Topic: Hoover Turbopower 2: U2119 001. Motor Brushes Available?  (Read 4635 times)
« on: January 23, 2017, 01:33:48 pm »
I was gifted quite a presentable one of these yesterday, I don't normally have much time for 90's Hoovers, but since it was otherwise going to the tip, I thought I'd have a go at reconditioning it.
It's all complete and not too bad once the grime is off, but the motor brushes are well worn down, so I thought I'd change them while it's in bits. But a couple of hours later online and I've drawn a blank with a source for these-does anywhere know where I might be able to get some please?
The original Hoover part reference is L63F7.
Re: Hoover Turbopower 2: U2119 001. Motor Brushes Available?
« Reply #1 on: February 08, 2017, 01:59:33 pm »
I doubt you will have much luck tbh, but they might be the same size as something else? I have an old book from Quаltex that lists all the carbon brushes they ever made/make, I'll have a read later and post up what I find, then Stu might be able to lay his hands on them.
How worn down are they though? I've had less than 1cm before and it's been OK, I've got a turbopower 1 down to 0.5mm in the loft that runs fine, but it's only 400w so doesn't have the potential to wear down so fast.
« Reply #2 on: February 08, 2017, 02:03:57 pm »
Thanks beko, they're OK for the moment (around 1cm), but while I had it in bits anyway for the stripdown, I thought I'd change the brushes as well.
Yes, you're probably right, I would have to use something similar and cut them down as required.
« Reply #3 on: February 08, 2017, 02:07:07 pm »
They would have been sold, but TP2 stuff seems to have gone very obselete. I would offer you some from one of my 3 tp2's but that would ruin them so that won't happen!
You'll probably have more luck finding a motor, the purepower/dustmanagerless is the same I think, and the Vortex, their Amtek jobs (although I doubt a DC01 Amtek would fit, but I've never tried tbh).
A 2200w dustmanager motor in a TP2 would be fun...
