Author Topic: dc07 high pitch whistling  (Read 5183 times)
Offline dsam
« on: January 29, 2017, 07:55:17 PM »
Hi, does any one actually know how to stop the high pitch whistling,shrill, howl watever you want to call it, also on other models too dc14, dc27 and more?
Re: dc07 high pitch whistling
« Reply #1 on: January 29, 2017, 08:15:18 PM »
Is this after a motor change?
Offline dsam
« Reply #2 on: January 29, 2017, 08:23:30 PM »
Possibly, but just aquired the machine and have had this on other dc models but the dc07 is terrible for it its a very high pitched whistleing that comes and goes.
Offline RustySkull
  • Kirby, Royal, Sebo =)
« Reply #3 on: January 29, 2017, 08:39:59 PM »
Probably an air leak. o.O
Offline dsam
« Reply #4 on: January 29, 2017, 09:16:26 PM »
well yeah, kinda guessed that, I buy sell an refurb dysons and its such a common fault just wondered if any body has actually cured the problem??
Offline Elgin
« Reply #5 on: January 29, 2017, 11:19:39 PM »
Ours used to do it before I removed every single, spring, washer and screw, plug every component, completely cleaned the cylones then re built it, fine now, sometimes the filter doesnt alway click in as well
Offline RustySkull
« Reply #6 on: January 31, 2017, 01:26:40 PM »
Haha made me laugh, usually checking every seal fixes it.
Offline dsam
« Reply #7 on: January 31, 2017, 01:56:16 PM »
Seems to be coming from the motor, if i take the bin off and hold my hand over the suction part of spine and vary the suction it does it. only seal there is around the motor, all ready done the seal trick around the motor rubber but it dont work.  :'(
Offline Elgin
« Reply #8 on: January 31, 2017, 06:06:10 PM »
Just looked on my 07 Animal, Remove the filter and on the side of the motor cover should be a black seal, Is it there?
Offline dsam
« Reply #9 on: January 31, 2017, 08:22:08 PM »
yes
Offline Elgin
« Reply #10 on: January 31, 2017, 09:10:40 PM »
yes
Ok, If you take out the filter, and unhook the belt/clutch if you can be bothered (Dont nessesarily need to for this test) without the filter does the whistle still hapen if so, then you need a new motor, possibly brushroll or clutch aswell but most likely motor. What colour(s) is the machine
Offline dsam
« Reply #11 on: February 01, 2017, 09:34:28 AM »
Thanks, will try this later. its a yellow clutchless, dont think the machine warrants cost of a new motor as only worth 45 to sell on as is, but thanks for reply.
Offline Elgin
« Reply #12 on: February 01, 2017, 03:57:03 PM »
Most likely the motor then.
