Author Topic: cleaning the cyclone on a DC07 Origin  (Read 3608 times)
Offline Matt
« on: February 24, 2017, 09:40:10 PM »
I want to disassemble the cyclone on my Dyson DC07 Origin as it needs cleaning. I've removed the head by taking out the 3 Torx screws; but I’m unable to separate the head completely because the end of the bin release rod is being held in place by a 3 arm collar half way down the inside of the cyclone. I’ve removed 3 screws on the outside of each arm; but can’t detach it. I’d also like to remove the fins and perforated collar in order to do a thorough clean; but the components seem locked tight.
Any help would be much appreciated
Many thanks
Matt
Offline RustySkull
  • Kirby, Royal, Sebo =)
Re: cleaning the cyclone on a DC07 Origin
« Reply #1 on: February 24, 2017, 10:47:35 PM »
I usually put the whole lot in the dishwasher, that's not for everyone mind you so sit tight and a Dyson geek will be with you shortly.
Offline Elgin
« Reply #2 on: February 25, 2017, 03:54:23 PM »
Many thanks
Matt
Hi, Just to make sure you didn't or don't do the mistake I did when I first did a Dyson Cyclone.
Make sure to release the bin flap, and remove the bin, then remove the 3 screws and work on the cyclone handle,
as for that little thing in the centre... I have seen them on pictures but on my DC07 Animal It hasn't got one so i'm not entirely sure. Mabey its stuck in with all of the dust that collects in there, try poking it with a flat driver.
And for the fins, well I struggled to get them off and eventually I just left them on
Offline RustySkull
« Reply #3 on: February 25, 2017, 08:32:09 PM »
You have to be so careful because the plastic is so weak :(
« Reply #4 on: February 25, 2017, 09:33:39 PM »
The collar is just stuck with crud, you need to gently tap the arms with a long thin "thing" then tug on the top, repeat as necessary.
« Reply #5 on: March 12, 2017, 10:27:25 PM »
Some of these questions are in the stickies: https://manchestervacs.co.uk/DysonForum/index.php/topic,459.0.html
