Author Topic: About the Dyson DC01  (Read 18824 times)
« on: October 01, 2010, 03:45:12 PM »
DC01 - The first UK Dyson model was the DC01, an upright vacuum cleaner priced for home use. It used patented Dual Cyclone technology. It was released in 1993 and was a best seller in the UK. They look like this:
They are becoming a bit retro now. Typically grey/yellow, occasionally grey/blue and on rare occasions available in the red, purple and yellow "De Stijl" colours you see above on the right. They are not as sophisticated as later models, but they are built like a tank and last for years.
These were -- and still are -- so popular, we still sell reconditioned ones despite the oldest ones being almost eighteen years old! You can get a reconditioned one here: Reconditioned Dyson DC01 and you can get parts from us here: DC01 Spare Parts.
Re: About the Dyson DC01
« Reply #1 on: November 09, 2014, 02:57:55 AM »
I thought I'd update this after four years. We no longer routinely sell reconditioned DC01 machines. But if you really, really, really want one, we might be able to get you one if you >>contact us<<. Or sometimes, the good people, collectors and enthusiasts on the forum here have nice ones to sell if you make a fresh topic and ask for one.
The reason for the topic update after four years was because of this topic and our recent update to the room title to include the lesser known DA 001 Dyson.
Wikipedia distinguishes the DC01/DA 001 thus:
Quote
The first vacuum cleaner sold under the Dyson name was the DA001, launched in 1993. It was a domestic upright model that used the patented "Dual Cyclone" technology and was made in Chippenham, England. After a short period, it was renamed the DC01 and production later moved to Malmesbury, at the company's new factory/research centre.
The DA001/DC01 had a single motor which provided the suction and also drove the brushroll directly via a single rubber toothless belt with no form of "brush control" (where the user can turn off the brushroll for use on hard floors), so was mainly designed to use on carpeted floors. It stored its hose on the back of the housing as part of the handle wand, and removing the handle wand enabled this stretch hose to be used. This was the only Dyson upright not to use washable pre-motor filters; these had to be purchased and replaced every 3 months. It also had a choice of post motor filtration – standard or HEPA (High Efficiency Particle Arrest) according to the model purchased.
For ease of parts identification, we have a sticky topic on the subject of fixed and swivelling soleplates: Dyson DC01 Variants: Fixed and Swivelling Sole Plates -- The Differences.
The fixed soleplate looks like this:
And is not generally available new any more. Used ones are equally scarce in good order.
The DA 001 is also easily identified by two other features, the "DYSON" typeface on the cyclone:
And the same typeface and "DA 001" model code on the ID plate:
*Credit to Beko1987 here for the photos*
There are other slight differences between standard DC01's and the early DA 001 machines (and I am working from memory here so someone correct me if I am inaccurate or make additions as necessary).
  • All are yellow and grey (no grey/blue or yellow/purple/red De Stijl made yet)
  • The cleaner head and front bumper differs a little in design - one doesn't easily fit the other
  • Original back hoses were about an inch shorter (but after-market ones fit either)
  • Wands had a white plastic collar on the end of the aluminium tube and were a tad longer on the tube (hence the shorter hose)
The DA001 and DC01 are essentially the same machine, the DC01 is basically a facelift of the DA 001. Most parts are interchangeable, most new after-market parts fit both variants (but after-market bumpers do not fot DA 001's), but if sourcing original used soleplates, cleaner heads, bottom motor housings, hoses or a wand, better to ask the question here to see if what you intend to buy will fit, or take pot luck. Because chances are the seller (unless a Dyson guru like some folk here) won't have a clue and you will be left wondering why the £5 used hose from eBay wont fit your DC01/DA001.
« Reply #2 on: November 09, 2014, 11:12:53 AM »
I believe the very early models were assembled in South Wales, before Dyson took assembly in-house at Chippenham? So would the switch from DA001 to DC01 coincide with that move?
I've never come across a DA001, how long were they in production?
« Reply #3 on: November 09, 2014, 11:30:22 AM »
Glad to see an update to this topic! Especially now DC01s are shifting into collectors territory rather than daily vacuum!
Help yourself to as many pics as you need, I'll put more up when I get it refurbished!
Offline absolutepurplelime
« Reply #4 on: November 09, 2014, 10:45:07 PM »
My neighbour had a da001 beko. It ended up in a skip and I was gutted :(
« Reply #5 on: November 10, 2014, 01:44:06 AM »
Shame! I've never really given them much though before, but I suppose they are quite rare now. I know of a few in the hands of other collectors though, so some are saved!
DA001 Brushroll housing here - http://www.ebay.co.uk/itm/DYSON-DC01-FOOT-HEAD-KICK-PLATE-BRUSH-BAR-COVER-/201194604000?pt=UK_Vacuum_Cleaners&hash=item2ed82205e0
I saw a job lot of DC01s earlier with a DA001 in there, can't find it now!
« Reply #6 on: November 10, 2014, 02:19:15 AM »
« Reply #7 on: November 10, 2014, 02:23:28 AM »
I'd say you guys are probably the best place for DA001 stuff now. Most other dyson recyclers probably don't know the difference, and put it with all the other dc01 stuff.
I posted it on Dysons wall, and was asked to email the ratings plate over and they would try and date it. Long shot, as I've tried this before with Dyson and got nowhere, but you never know!
« Reply #8 on: November 10, 2014, 02:31:23 AM »
http://www.dailymail.co.uk/news/article-98618/800-jobs-axed-Dyson-moves-Far-East.html
1993-1995 according to the mail. Bet any info about the company then is looong gone...
DC01 Spare Parts
