Author Topic: 2005 clutch slipping - new belts etc.  (Read 3801 times)
Offline Elgin
« on: April 08, 2017, 12:18:49 AM »
Got a 2005 clutch -
Brushroll spins slowly when machine is upright - like really slowly - as soon as a finger goes near is stops but the clutch starts slipping - no ratchet and the belts are tight - clutch is slipping not the belts - did flip the clutch pad as the one side is entirely smooth - when flipped over immediatly worn through the other side - both sides now completely bare and its been flipped onto the what was brand new - now nearly bare side about 1 month ago... white wheel slightly worn but not much - one small black line on it. Ive tried new pully in it and new
Re: 2005 clutch slipping - new belts etc.
« Reply #1 on: April 08, 2017, 07:19:25 AM »
What are the bearings on the brushroll like?
Offline Elgin
« Reply #2 on: April 08, 2017, 11:47:04 AM »
Bearings are fine - different brushroll - no difference
Offline AdamF
  • Dyson,Sebo,Miele
« Reply #3 on: April 08, 2017, 11:59:01 AM »
If you are confident enough then i would recommend opening the clutch and flipping over the clutch plate its the cog type material that should sort your issue.
Offline Elgin
« Reply #4 on: April 08, 2017, 12:40:51 PM »
Yeah done that couple times - wears through the pad imediatly
« Reply #5 on: April 08, 2017, 07:23:47 PM »
Is it rebuilt properly? Sounds like the cogs aren't sitting right and the metal plate is in contact with the pad at all times
Offline Elgin
« Reply #6 on: April 14, 2017, 05:26:17 PM »
ill check is soon, doing refurb on a DC14 animal today
DC04 Spare Parts
