Author Topic: Dc22 with dc08 floor tool possible  (Read 10653 times)
Offline Mike.heath
« on: May 02, 2017, 12:46:48 pm »
Hi everyone, been a dyson owner like most people since day 1. My current dc22 is going strong but have a knackered floor tool. Also owning a dog and constant hair clogs I decided to pick up a used dc08 turbo or turbine head ... But....
My wand doesnt fit onto the head tool... Easy I thought there must be an adaptor.... What a mine field
 Two hours later and totally confused
Does anyone simply know what I need please?
Offline Mike.heath
Re: Dc22 with dc08 floor tool possible
« Reply #2 on: May 02, 2017, 03:41:47 pm »
Actually I already have this and the combination doesn't work
« Reply #5 on: May 02, 2017, 06:56:32 pm »
Elgin is wrong.
I am not aware there is a reliable adaptor to do what you want. But there may be a work around.
The DC08 head you have, measure across the inside of the tube hole. What does it measure in mm?
Also a photo of the tool ends of old and new would help.
You are correct this is a minefield. Especially with DC08 and DC19 heads. Why we sell >these<.
The other problem you have is any head that is bigger than your original will struggle to spin very fast as the DC22 is a smaller machine than normal with less suction than a full size cylinder.
« Reply #6 on: May 02, 2017, 07:00:58 pm »
Is it this
http://m.ebay.co.uk/itm/New-to-Old-Tool-Adapter-For-DYSON-DC22-DC23-DC23T2-DC24-Hoover-Connector-32mm-/252224445243?nav=SEARCH
Also caution: The photo on that listing is our adaptor and our design, that is not the one Sparesworks/spares2go actually sell or send. They sell an inferior one with a much longer end on. They are dishonestly using a photo of our product.
Offline Mike.heath
« Reply #7 on: May 02, 2017, 07:27:20 pm »
Thanks for update. I'll buy it from you guys. Do you have a direct link plz
Offline Mike.heath
« Reply #8 on: May 02, 2017, 07:32:29 pm »
Internal diameter 30. external 33mm dc08 head
Internal diameter 35mm external 38mm dc22 wand
Offline Mike.heath
« Reply #9 on: May 02, 2017, 07:38:01 pm »
This listing sells the head with an adaptor listed for my machine... Any idea what adaptor it is as it must be possible
Look at this on eBay http://www.ebay.co.uk/itm/281770978108
Offline Elgin
« Reply #10 on: May 02, 2017, 08:39:35 pm »
if its the same as my adapter - its one which comes with a Mini Turbine tool - im no help really there... :'(
Offline Mike.heath
« Reply #11 on: May 09, 2017, 09:07:19 am »
Hi guys do I bought the turbine tool which fits the head and the adaptor kit which fits my dc22 but they don't match up so I'm still in the same conundrum lol. 3 converts and 2 variants of cleaner and no combination works!!! Any ideas am i missing a critical pieces?
Offline Mike.heath
« Reply #12 on: May 09, 2017, 09:15:37 am »
Photo of what I have
Offline Mike.heath
« Reply #13 on: May 09, 2017, 09:18:31 am »
Only one I don't have is this but I assume it connects oto a hose not a wand
http://dysonvacuumspares.com/index.php?route=product/product&path=66&product_id=1030
« Reply #14 on: May 09, 2017, 12:36:45 pm »
That isn't for that.
I said above there is no easy answer to this particular combination.
Using what you have, and something like Araldite, you could do this:
Butting the two at each end together and glueing a sheath tube over the both (like household waste pipe) would also work.
Hardly ideal, but you are not going to find a plug and play solution.
Will the long knock off of our adaptor you bought not glue straight into the 32mm hole in the head?
