Author Topic: Using WD40 on Dysons  (Read 29404 times)
Offline RustySkull
  • Kirby, Royal, Sebo =)
« on: May 01, 2017, 08:54:00 PM »
WD40 is fine with plastic, I've used it for years including on Dyson's flimsy plastic with no issues. I use it on everything to clean as well as oil and prevent corrosion.
Offline GeorgeJ
    • Some dirty pics ;)
Re: Using WD40 on Dysons
« Reply #1 on: May 01, 2017, 09:30:01 PM »
Great to hear!  I had a DC28 brushbar which was rusted badly.  I was afraid to use WD-40 on it, so I kept dropping in a bit of electric motor oil into it, spinning it and wiping out the muddy grime.  Did that about 100 times.  :angryman: :))
 -Michael Scott  -GeorgeJ
Offline Elgin
« Reply #2 on: May 02, 2017, 12:55:23 AM »
I could of done with some of oil in one of my spare dyson motors before I literally chucked it down the driveway for the scrap metal collectors - Spilt tiny bit of screen cleaner into the top bearing of a YV-511 - ate dry all the oil and grease out of the bearing and seized the bugger up...
Offline RustySkull
« Reply #3 on: May 07, 2017, 10:11:48 AM »
Haha, remember WD40 is only oil, it's designed to oil and also clean, you can use it for all sorts of things... Starting engines, driving out water, oiling etc... It won't damage anything, very good stuff :)
I've used it to clean whole Vacuum's before :)
Offline GeorgeJ
« Reply #4 on: May 07, 2017, 12:51:21 PM »
That's good to know.  I'm always afraid of melting plastic bits off.
« Reply #5 on: May 07, 2017, 01:52:42 PM »
I did that with a cuckoo clock once and brake cleaner, everything was fine until the bird melted  :boggleeye:
Offline GeorgeJ
« Reply #6 on: May 07, 2017, 03:04:31 PM »
Hahahaha...   I mean, sorry for your clock...
« Reply #7 on: May 07, 2017, 04:18:03 PM »
Clock was fine, still is just had to get a new birdy for it  :grinn:
Offline GeorgeJ
« Reply #8 on: May 07, 2017, 10:55:06 PM »
Please tell me you have a photo of the melted bird
« Reply #9 on: May 08, 2017, 11:21:16 AM »
Sorry
Offline GeorgeJ
« Reply #10 on: May 08, 2017, 11:38:02 AM »
I knew this forum would break my heart
« Reply #11 on: May 08, 2017, 01:16:43 PM »
WD40 isn't much good on motor or brushroll bearings as it dries out when it gets hot and glues it up again. A silicone based lubricant is much better.
Offline GeorgeJ
« Reply #12 on: May 08, 2017, 02:13:14 PM »
I've heard that silicone is bad for high speed applications because of some molecular mumbo jumbo it tends to shear instead of creating a floating barrier between the surfaces.   I say heard because I don't remember the source or if they were reliable.
« Reply #13 on: May 08, 2017, 07:31:11 PM »
3 in 1
« Reply #14 on: May 08, 2017, 07:43:58 PM »
Grease is good
