Author Topic: Dyson DC14 (with clutch) - Motor Replacement how to guide!  (Read 40262 times)
I took these pictures ages ago (back in November 2016 I think) , so thought it best to write them up! This will show you step by step how to change the motor in a clutched DC14!
You will need:
An Motor - https://manchestervacs.co.uk/Dyson/DC14-spares.html/dyson-motor-ydk-yv-dc04-dc07-dc14-dc27-dc33
An Post Motor Filter, either -
             Pad - https://manchestervacs.co.uk/Dyson/DC14-spares.html/DC07-DC14-Post-Motor-Filter-Pad
             Or HEPA, depending on what your machine currently has, both are interchangeable though) https://manchestervacs.co.uk/Dyson/DC14-spares.html/DC07-DC14-HEPA-filter
A Belt Lifter makes the job alot easier (https://manchestervacs.co.uk/Dyson/DC14-spares.html/Dyson-Belt-Removal-Tool) but it's not critical.
Right, onto the job itself!
Remove the bin
Remove the cable
Remove the Wand
and remove the hose
Next, undo this screw behind the switch
Then, with a flatblade screwdriver, gently pop these tabs back (I think this is the last thing to be written up with images from my old phone thank goodness!)
They just push back into the machine (which half pushes the switch cover off in the process on the other side)
Re: Dyson DC14 (with clutch) - Motor Replacement how to guide!
« Reply #1 on: May 14, 2017, 09:21:14 pm »
You will see it separating
Just pull it off!
Here is the switch and mains cable join
Pull it all out
Open the black box and separate the two blue wires
Pull the brown wire from the switch and the cable is off! Remove the other wire from the switch too
Feed the spinal cable out the back of the chassis, and pull it from the cable run
Next, we need to remove the Post Motor Filter. If you have suffered the full house motor blowout this will be messy...
Pop the two tabs carefully up
« Reply #2 on: May 14, 2017, 09:26:10 pm »
Then one last tab at the front
and off it lifts!
This isn't the worst one I've seen! If it properly catches fire this goes all crispy!
Now, remove the clutch cover. Prise it off from the top and bottom of the join with a good screwdriver, the clips will give up fairly easily
Now flip the machine over, and twist the 3 tabs 1/4 a turn and remove the base plate
Lift the belt if you have the lifter, or just remove the brushroll
At this point, go and cut all the hair and threads off your brushroll! It's much easier when it's out of the machine
« Reply #3 on: May 14, 2017, 09:31:55 pm »
Now to remove the inner brushroll housing. I use a screwdriver very carefully at the edges by the pivot points. A slight prise up and they pop out. Keep everything square though
When it's hanging, pull the internal hose off the machine
Remove the wand u-bend suction channel
Then, remove the clutch cover. Put the machine in the 'upright' position if it isn't already. One screw is hidden 10cm down in this hole
The other two are more easy to spot! Then lift the cover off and out
Pop the motor to clutch belt off
Grab both belts and pull HARD AND FIRMLY
And off it comes! If the belts are knackered or the white wheel has melted away, search the forums because we have rebuild threads, and Mvacs sell the white wheel, or a reconditioned clutch.
« Reply #4 on: May 14, 2017, 09:36:10 pm »
Now for the main head. Either side is a plastic circlip. Pop one end up and the rest will follow
Once removed, flop the machine down like so
Then pull either end out slightly
and lift the head off the vacuum
Remove the air path cover next to the motor by pushing up the clip and lifting the cover off
Now, remove 4 screws. 2 here on one side
ila_renderedila_rendered
« Reply #5 on: May 14, 2017, 09:42:31 pm »
And two the other side
Lift the motor unit off the chassis and pull the wire through
Pull the edges of the front cover out and lift off the motor housing
Push this cable grommit into the housing
Then release the 4 tabs holding  the locking ring onto the housing
On some flooring that won't be marked, hold the motor belt spindle down by the housing, and push hard. It should move upwards an inch, then grab the black fancase seal and pull the motor out. The wires will either come easily or get caught on this part here
The old motor is out!
Remove the rubber seals and give them a bit of a clean so they seal nicely again, and clean the motor housing (if it's filthy, pop it in the dishwasher or wash it with soapy water and a brush! Dry it obviously...)
Now, get your new motor and we can begin re-assembly
« Reply #6 on: May 14, 2017, 09:53:35 pm »
First, connect the wires back up, and possibly pop a lick of tape around the connections so they don't pull apart, because it's annoying having to strip the entire thing down again just to pop a wire back in!)
Rubber it up. The belt spindle end is keyed with a fat and thin protrusion. Hold the motor like so, observing where the cable will sit around the side of the carbon brush and exits the motor housing, then fit the seal to the motor so the keyed segments will be in the correct location.
Pop a thin smear of grease or WD40 or childrens bubble solution around the inside of the motor housing
Then slide the motor home, ensuring the seal fits properly
Refit the locking ring, it's keyed too so only goes on one way
Pop the cable back through the machine using this hole
Refit the outer trim to the motor housing, then fit that to the chassis (lean the chassis up against something, it makes it much easier!) The housing should sit like this against the inner channel
Put the 4 screws back in and run the cable up the machine and into the switch housing area
« Reply #7 on: May 14, 2017, 09:58:24 pm »
Pop the air duct back on
Fit a new post motor filter
Then snap the cover back down (it slides into the back first, then pushes down and clips on)
Refit the main cleaner head
And check the changeover valve operates properly, and re-fit the circlips
Clutch now. Before fitting the clutch, ensure it's the correct way up, then slip the small belt over the motor spindle. Then fit the clutch to it's housing, ensuring the locating groove is met at the top and bottom, it should push nicely flush with the screw posts
Ensure the metal belt guard is fitted to the clutch cover
« Reply #8 on: May 14, 2017, 10:02:44 pm »
Then fit that and screw it down!
Brushroll housing now, fit the hose to the machine first (push fit)
Then fit the housing to the head. The hose acts as a spring too, when you push on the back of the brushroll housing it should spring back nicely. If it does not, rotate the hose a fraction either way until it does, or replace the hose as it's knackered)
Refit the brushroll
and base plate
U-Bend on
Switch now, pop the mains cable back in and route the cable
Connect the switch and neutral wire up
« Reply #9 on: May 14, 2017, 10:07:39 pm »
Rest the switch button on the switch
Then lower the housing over that, check both tabs click in and pop the screw in
Refit the hose, wand and take it for a test drive! I hope the wires didn't pull apart on you...
All done! I hope this helped, please comment if you have any questions, there's about 20 of us on here who can help!
Offline Elgin
« Reply #10 on: May 14, 2017, 11:32:06 pm »
Great thread as always Beko!
BTW - did you cut the cable back a bit? I noticed the spades wern't the original dyson ones on the power cable, and the plug doesn't quite go round the top cord hook? anyways good work!
Edit: just noticed its a difffernt machine from the start - at the end its an animal, the start it had all the white buttos etc.
« Reply #11 on: May 15, 2017, 07:19:20 am »
Well spotted! Yes the cables cut back, they break as they enter the machine regularly
Offline mrdyson
« Reply #12 on: May 15, 2017, 08:18:45 am »
Great guide  :tiphat:
Offline GeorgeJ
    • Some dirty pics ;)
« Reply #13 on: May 15, 2017, 03:13:10 pm »
Excellent work!  It was a guide like this which helped me fix my own and both got me into Dysons and got me to this forum (for better or worse! :))).
Thanks, Beko!
 -Michael Scott  -GeorgeJ
Offline Elgin
« Reply #14 on: May 15, 2017, 03:53:57 pm »
Thanks, Beko!
Definatly for better  :underchair:
