Author Topic: 1988 Electrolux 612 Electronic - Stripdown and Refurbishment  (Read 10601 times)
Hi! Some years ago now (09/01/2015 looking at the first picture  :underchair:) I won this from ebay for 99p!
Initially I was excited, but when I got it back to my mums for a proper look, it was not all good. The brushroll was melted at one end and fully shot
The plastics were in dire need of a polish
The handle was broken
But the baseplate was pretty good
The ratings plate dates it to week 34 1988, a mere few months younger than me!
Looking at the pictures available to me I seem to have removed the base plate
Removed the ruined belt
And had a closer look at the brushroll to see if it was saveable
Re: 1988 Electrolux 612 Electronic - Stripdown and Refurbishment
« Reply #1 on: May 25, 2017, 09:54:40 PM »
It wasn't...
Sadly, these brushrolls (They fit the 600 series, Contour, Glider and Airstream, and the Dirt Devil 6110) are hens teeth, so it went into the back of the shed for a long time
Until last month infact!
Because, amazingly, someone was selling 12 BRL21's, so I grabbed 2 (one for a contour I have had for a while...). (Stu, if you hear of Q finding loads of these, get them! The 12 sold out within 2 weeks @ 13 a go plus postage...)
So I filmed the before refurb video
Not a valid youtube URL
And here we go  ;D ;D ;D
Cable removed
Hose re removed
Wand and crevice tool removed
Handle removed
Speaking of the handle, this sticker is interesting. Not to me (well, slightly), but to a member of our pages, Sebo Steve, or Mr Steve Green, Manchestervac's friendly* Sebo area rep! Apparently he used to work at this very vacuum cleaner shop back in the day before reaching the heady heights of working for Sebo with a company 320d and mobile phone, he may have even touched this VERY vacuum. Sadly it was peeling of, so I removed it, but here it is for prosperity!
I did try to split the handle fully but it's not meant to, so I left it
The holder for the missing crevice tool pops out easily
« Reply #2 on: May 25, 2017, 09:59:26 PM »
Moving down now, and the bag door comes off
The bag full indicator comes out
And splits down for cleaning as it's full of dust!
The latch pops out from the top, the metal bar provides it's self returning spring
The bag door seal comes out as well
This bag was in it when I got it, and well fit for the bin now!
Under here should be some wires
Yep...
« Reply #3 on: May 25, 2017, 10:06:46 PM »
Working from the top, the speed control knob lifts off
And splits down slightly
The power button and it's surround lifts out too
Time to undo the wiring
The mains cable comes in at the front right of the block
Opposite that is a neutral that runs to the motor, and a live to one side of the switch.
From the switch the live goes to the PCB, which comes out again and through the choc block to the motor.
The supressor connects over the neutral, with an earth that goes straight to the motor and earths there
Simple!
Very common electrolux switch this is
Mains cable removed
and once the motor wires are undone the pcb and speed module can be removed
Made in Tyne & Wear, rather than happy factory 5 in china!
« Reply #4 on: May 25, 2017, 10:12:12 PM »
With all that removed, the spinal cable can be pulled out and down
The mains cable grommit pulls out too
The bag latch pulls out of the bag compartment
And we are done up the top! So onto the bottom
The baseplate has to come off first. The screws are identical to DC01 soleplate screws and retaining washers, just flat head not philips
I popped the metal gliders off
And removed the brushroll
Now this took some figuring out, but 4 screws hold an internal chassis in place, which lifts out and makes the hood fall off too
« Reply #5 on: May 25, 2017, 10:17:56 PM »
The chassis holds the wheels, height adjustment mechanism and release pedal
The height adjuster knob unscrews from the assembly
The rear wheels are removed by pulling the axle out, not even a circlip needed as it's all held together when the chassis is in place
This part sort of fell out, but it's what makes the front wheels move up and down according to the surface being cleaned
Once that is removed, the front wheel assembly comes out
All 4 wheels slide off
The release pedal is sprung by this spring, which hooks underneath the chassis
With that released the pedal pops out of it's pivots.
Chassis done, onto the hood next
« Reply #6 on: May 25, 2017, 10:25:15 PM »
Which doesn't really hold too much, the furniture guard comes off
As does this belt guard
And that's it! Now, we can open the motor cover!
The suction duct sits infront of the fancase, and lifts out
The motor itself then lifts out
Last out is the pre motor filter holding cage
Onto the motor itself, the bracket that holds it steady on the belt spindle side is removed, as are the seals
Sadly, Electrolux motors from the 500 series until the airstreams, both cylinder and uprights (dolphin motors are the same, just without the belt spindle) are non servicable, you can't componentise them as you can Hoover's motors, however, you can pop the two clips and remove the top part of the motor
And get to the bearings, which you cannot remove as the flat end stop is crimped onto the end of the belt spindle... Luckily these were not completely shot, and responded well to a good soak in 3 in 1 oil and a clean up, which is all that can be done.
« Reply #7 on: May 25, 2017, 10:29:37 PM »
On 500 series motors, there is a spring around the ends of the fans which does something to improve suction, but also has a great reputation for clogging up with fluff and killing all the suction, so I removed the dry tape and lifted the fancase off
And found no spring. Oh well, I refitted it with nice fresh tape
And with the motor spinning very smoothly now, washed and dried all the plastics. Then, gave them a polish
And cleaned the plug up
First back in was the pre motor filter holder
Then it was time to open some nice new old filters
One of which had gone a bit crumbly
But the other one was fine
« Reply #8 on: May 25, 2017, 10:31:04 PM »
 :chuckle:
Mum had one of those, handle snapped clean off in the end. Dad and I took the floor plate off used the height adjuster to cover the motor shaft and turned it into a cylinder machine, we used it in the caravan at Caister for years.
« Reply #9 on: May 25, 2017, 10:33:38 PM »
I fitted the new post motor filter too
And put the cover on
Next, it was time to rubber up the motor
Fit the holder
And dropped it in
Running the cable up to the top
Hood now, and the bumper is fitted
As is the belt guard
Inner chassis now, release pedal replaced
« Reply #10 on: May 25, 2017, 10:39:01 PM »
And popped the spring back
Middle wheels assembled with a nice smear of grease to stop them squeaking
And fitted to the holder
Floaty springs fitted
With the white part (which, thinking about it actually pushes the wheels down when put into upright mode to lift the brushroll off the carpet when using the tools!) fitted
Height adjuster fitted
The hood is laid in place, with the suction duct for the brushroll housing fitted
A smear of grease on the rear wheel axles as well as the main machine pivots and the inner chassis is screwed down
Brushroll and belt fitted
« Reply #11 on: May 25, 2017, 10:43:50 PM »
Metal plates back in with a tiny bit of bending about
And fitted!
Down here is done!
Bag holder fitted
And the wiring and grommit can start to go back in
I de-supressored it
Because it was starting to bulge
Wired up
Controls fitted
« Reply #12 on: May 25, 2017, 10:47:09 PM »
And popped the cover on
The cleaned and plumper bag door seal went on
latch refitted
And the bag full indicator reassembled and fitted
I glued the handle back together and fitted the tool holder
and put everything else on
And that was that!
« Reply #13 on: May 25, 2017, 10:51:32 PM »
And that was that! I put it on ebay using the above pictures, with a pack of genuine bags and filters I had lying around, starting it at 19.99 to cover costs, and put what I thought was a fairly silly buy it now on, well blow me if someone didn't hit the button not 24 hours later for 75 plus 15 post! Result! The chap used to repair them back in the day (there's a pattern here) apparently and fancied one again for nostalgia. So I boxed the crap out of it and it arrived safely and I presume he is very happy with it!
And I'm very happy with it too!
Madrat, how could you let your parents do that to such a lovely cleaner? For shame...
« Reply #14 on: May 25, 2017, 10:54:51 PM »
Forgot the after video!
The poxy hepaflo type Airstram bag I thought would fit popped off during that though, so I had to spend 10 minutes with the DC40 which I got that day cleaning it all back out, luckily it was only light dust and came right off!
