Author Topic: Do I Need A New HEPA Filter - DC23 (DC32)?  (Read 7505 times)
Offline Deep Blue
« on: May 30, 2017, 09:23:03 am »
Pulled apart DC23 (DC32) after water accidentally sucked-up.  Tried drying out motor but there was a high-pitched squealing sound and a slight smell of burning when I turned the vac on.  Anyway, now looking to replace the motor at this point as it is probably the issue - somehow not working as it should.  I assumed if the motor seen water then it wouldn't work at all - it works but there is the terrible sound and the smell... (separate post/thread on this)
Anyway, in the process of stripping the vac after the water incident I noticed that the HEPA filter (it was wet) that encases the motor was black/grey coloured on the inside - I presume this is due to the carbon from the brushes (unit is 6 years old)?
Do you think I need a new HEPA filter (pictures below)?
Offline mrdyson
Re: Do I Need A New HEPA Filter - DC23 (DC32)?
« Reply #1 on: May 30, 2017, 10:43:49 am »
The post filter is supposed to last the lifetime of the motor.
When replacing a motor, we always replace the filter as a matter of course.
Offline Deep Blue
« Reply #2 on: May 30, 2017, 01:48:01 pm »
Makes sense I guess.  Once I separate the fan from the motor I'll purchase a new motor and HEPA filter.
I guess the inside of the HEPA filter should be white though just like the outside and the black/grey colour is because of the wearing of the motor carbon brushes?
I guess there's no easy test to tell if there's still some life in a HEPA filter?  Carbon dust would block it up a bit?
« Reply #3 on: May 31, 2017, 08:30:27 am »
It doesn't look horrific, but having been wet the pores might have clogged up as their only paper, so you could get it back together and find it overheats the motor after a few days/months/years.
No real way of knowing short of getting your wallet out or re-assembling it once dry and finding out. Your finding out now why us repairers steer clear of the newer cylinders, the cost soon adds up!
Offline Elgin
« Reply #4 on: May 31, 2017, 12:35:16 pm »
No, The filter will be black after that period of time. I had a new filter fitted to a dyson, and it was a light grey withing a few weeks - if after 6 years the filter isn't black then id love to know whats happening to all the carbon...
« Reply #5 on: June 05, 2017, 01:17:54 am »
Yes.
Offline Elgin
« Reply #6 on: June 05, 2017, 02:15:02 am »
Yes.
as MVacs said
; you will need a new one
