The small bearing on the ball will have worn, With no weight on the ball dose it wobble if you grab it and twist? Its a simple and cheap job to do. There will be a thread on the forum, probably a rebuild by Beko that will show you how.
Quote from: Madrat on June 22, 2017, 04:01:21 PMThe small bearing on the ball will have worn, With no weight on the ball dose it wobble if you grab it and twist? Its a simple and cheap job to do. There will be a thread on the forum, probably a rebuild by Beko that will show you how.That's the dc24 that does that!
