Author Topic: Dc25 stopped working  (Read 4944 times)
Offline olearysp
« on: August 05, 2017, 08:51:31 pm »
Hi my dc25 ball motor has stopped working. Just before it stopped it sounded be running faster and then just stopped, the fuse in the plug is okay. When I opened the ball I could see that the ball air filter had been removed . Could this have caused the motor to fail.
Offline ollivacguy
Re: Dc25 stopped working
« Reply #1 on: August 05, 2017, 11:44:16 pm »
Having the post motor filter wouldn't have made a difference, however, the motor may have blown due to an unknown cause. Beko1987 will have the answers failing that Mvacs forum is a place filled with knowledge on such things!
« Reply #2 on: August 06, 2017, 12:30:10 am »
I would suggest main motor has had it, probably due to filter in past being neglected.
« Reply #3 on: August 06, 2017, 10:38:25 am »
Yup. What he said.
Offline olearysp
« Reply #4 on: August 07, 2017, 07:17:31 pm »
Thanks for your advice. If I get the motor replaced what are the implications if I ran the dc25 without the ball motor filter ? As I just want it for hovering the car etc.
« Reply #5 on: August 07, 2017, 07:22:09 pm »
Does not make a lot of difference to be fair. Will be a bit noisier.
Offline olearysp
« Reply #6 on: August 08, 2017, 08:48:15 pm »
Okay thanks
